メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Machine Wash a Wader
必要な工具と部品
    1. How to Machine Wash a Wader, Prepare the wader: 手順 1、 2の画像 1 How to Machine Wash a Wader, Prepare the wader: 手順 1、 2の画像 2
      • Shake off any excess dirt, zip all zippers, and remove any detachable parts like waistbands or belts.
      FixBotに聞いてみる
      コメントを追加
    2. How to Machine Wash a Wader, Secure the straps and fasteners: 手順 2、 3の画像 1 How to Machine Wash a Wader, Secure the straps and fasteners: 手順 2、 3の画像 2 How to Machine Wash a Wader, Secure the straps and fasteners: 手順 2、 3の画像 3
      • Untangle any straps.
      • Close or clip any fasteners or buckles.
      FixBotに聞いてみる
      コメントを追加
    3. How to Machine Wash a Wader, Load the washing machine: 手順 3、 2の画像 1 How to Machine Wash a Wader, Load the washing machine: 手順 3、 2の画像 2
      • Put your waders in the washing machine.
      • Add detergent to the washing machine. You can use special technical gear soap or gentle laundry detergent.
      • Avoid detergent containing fabric softeners, stain removers, perfumes, whiteners, or bleach.
      FixBotに聞いてみる
      コメントを追加
    4. How to Machine Wash a Wader, Set the washing machine: 手順 4、 2の画像 1 How to Machine Wash a Wader, Set the washing machine: 手順 4、 2の画像 2
      • Set the load size to small.
      • Set the water temperature to cold.
      • Set the wash cycle to normal or gentle/delicate/permanent press. If possible, add an extra rinse cycle to ensure all residues are removed.
      • Set the spin cycle to low.
      • Start the washing machine.
      FixBotに聞いてみる
      コメントを追加
    5. How to Machine Wash a Wader, Dry the waders: 手順 5、 3の画像 1 How to Machine Wash a Wader, Dry the waders: 手順 5、 3の画像 2 How to Machine Wash a Wader, Dry the waders: 手順 5、 3の画像 3
      • Let your waders drip dry as soon as possible by hanging them somewhere and letting excess water drip off.
      • Air dry the inside of your waders by turning them inside-out and hanging them in a shaded, well-ventilated area until the inside is completely dry.
      • You can do this outdoors or in the area where you plan to store them. Laundry lines, ladders, and trees are all great options for air drying. This may take up to 24 hours.
      • Air dry the outside of your waders by turning them right-side-out and hanging them in a shaded, well-ventilated area until the outside is completely dry.
      • Store your waders properly by hanging them by the shoulder straps or on a specialty wader hanger in a well-ventilated storage space.
      • Avoid using a dryer unless the waders have been deeply cleaned with soap first.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
247,021 ポイント
1,203のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 9
過去 30 日: 35
今までの合計 638
