メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Fix a Mirror Frame
必要な工具と部品
  1. How to Fix a Mirror Frame, How to Fix a Mirror Frame: 手順 1、 1の画像 1
    • Gather all your broken frame pieces and gently clean off any dust or debris. Once the pieces are clean, arrange them to determine how they fit back into the damaged section. This will help you understand the order in which they need to be glued.
    FixBotに聞いてみる
    コメントを追加
  2. How to Fix a Mirror Frame: 手順 2、 1の画像 1
    • Once the pieces are arranged, apply a small amount of Gorilla Glue to the edges that need to be reattached. Press each piece firmly into place. Work slowly to make sure each section aligns with the original shape of the frame.
    • Caution: Gorilla Glue expands as it dries. Use sparingly to prevent overflow onto the visible surface.
    FixBotに聞いてみる
    コメントを追加
  3. How to Fix a Mirror Frame: 手順 3、 1の画像 1
    • Use tension bands (rubber bands or elastic straps) to hold the pieces tightly together while the glue cures. Place the bands so that they apply gentle, even pressure across the repaired area without pressing against the mirror glass. Let the glue dry according to the instructions on the adhesive bottle.
    FixBotに聞いてみる
    コメントを追加
  4. How to Fix a Mirror Frame: 手順 4、 2の画像 1 How to Fix a Mirror Frame: 手順 4、 2の画像 2
    • Once the glue is fully dry, check for any gaps or visible seams between the pieces. Use clay or wood filler to fill in the gaps to create a smooth, continuous surface. Shape the filler to match the pattern and curves of the existing frame. Allow the filler to dry completely before moving on.
    FixBotに聞いてみる
    コメントを追加
  5. How to Fix a Mirror Frame: 手順 5、 2の画像 1 How to Fix a Mirror Frame: 手順 5、 2の画像 2
    • After the filler has dried, mix your paint to match the color and finish of the frame. Use a small brush or sponge to apply the paint to the repaired areas. Blend it carefully so it matches the rest of the frame. Allow the paint to dry fully before handling.
    FixBotに聞いてみる
    コメントを追加
  6. How to Fix a Mirror Frame: 手順 6、 1の画像 1
    • Let the repaired mirror frame dry for 24 hours. Once everything is set, your mirror should be fully restored and ready to use again.
    FixBotに聞いてみる
    コメントを追加
ゴール
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Regina Bolanos
メンバー登録日: 06/11/25
133 ポイント
1ガイドが承認済み
チーム
University of North Texas, Team 40-2, Kilpatrick Summer 2025 University of North Texas, Team 40-2, Kilpatrick Summer 2025人のメンバー
UNT-KILPATRICK-SU25S40G2
1 メンバー
1のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 11
過去 7 日: 30
過去 30 日: 107
今までの合計 890
