はじめに
Slime can often be a source of relaxation and entertainment. However, if you've had slime for any amount of time, you're likely aware of how it shrinks and stiffens over time due to constant use. Thankfully, fixing this issue is a quick and easy process!
If you want to keep your slime active for longer, follow this guide to give your slime its stretch and gooey texture back! Make sure that you have a clean container to put your slime into, as well as space that is clear and uncluttered.
必要な工具と部品
ある他の人がこのガイドを完成しました。
