はじめに
Use this guide to enter error code mode and field service mode on select GE washing machines. These built-in diagnostics can help you confirm faults such as water supply problems, door lock errors, and out-of-balance conditions before you replace parts.
手順1 Prepare the washer
Unplug the washing machine for about five minutes and then reconnect power.
Ensure the display is blank and no cycle is running before proceeding.
手順2 Enter error code mode
Press and hold the Start/Pause button for 10 seconds until the display lights up.
Release the button when the first stored code appears.
手順3 Read stored error codes
Press Start/Pause again to cycle through each stored error code.
Two horizontal lines on the display mean you have reached the end of the list.
手順4 Exit error code mode
Press any button on the right side of the control panel except Start or Power.
Confirm the display shuts down and the washer exits error code mode.
手順5 Match the displayed code
Compare the code on the display with GE's fault list.
Use that code to focus your troubleshooting before replacing parts.
手順6 Enter field service mode
Press and hold the Start button while rotating the selector knob 180 degrees counterclockwise.
Release Start when the display begins flashing.
手順7 Run a service test
Turn the knob clockwise to increase the test number or counterclockwise to decrease it.
Press Start once to begin the selected test.
手順8 Exit service mode
Press and hold Start/Pause for 10 seconds to reset the washer.
Confirm the display returns to normal operation afterward.
手順9 Check consumer help alerts
Check for alerts such as H2O Supply when water flow is restricted or turned off.
Watch for a door alert if the washer does not sense a closed or locked lid.
If the spin light blinks, rebalance the load and inspect for out-of-balance conditions.
If the display shows Cancelled, close the lid and try again, or power-cycle the washer if needed.
Use the stored codes and service tests to narrow the fault before replacing parts. Exit diagnostics when you're done and return the washer to normal operation. Repair didn't go as planned? Ask our Answers community for help.
ある他の人がこのガイドを完成しました。
