メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
How to Access GE Washing Machine Error Code Mode
ビデオガイド
この修理ガイドはYouTubeビデオを書き起こしました。
      • Unplug the washing machine for about five minutes and then reconnect power.
      • Ensure the display is blank and no cycle is running before proceeding.
      FixBotに聞いてみる
      コメントを追加
      • Press and hold the Start/Pause button for 10 seconds until the display lights up.
      • Release the button when the first stored code appears.
      FixBotに聞いてみる
      コメントを追加
      • Press Start/Pause again to cycle through each stored error code.
      • Two horizontal lines on the display mean you have reached the end of the list.
      FixBotに聞いてみる
      コメントを追加
      • Press any button on the right side of the control panel except Start or Power.
      • Confirm the display shuts down and the washer exits error code mode.
      FixBotに聞いてみる
      コメントを追加
      • Compare the code on the display with GE's fault list.
      • Use that code to focus your troubleshooting before replacing parts.
      FixBotに聞いてみる
      コメントを追加
      • Press and hold the Start button while rotating the selector knob 180 degrees counterclockwise.
      • Release Start when the display begins flashing.
      • If you overshoot slightly, return the knob to its starting position and try again.
      FixBotに聞いてみる
      コメントを追加
      • Turn the knob clockwise to increase the test number or counterclockwise to decrease it.
      • Press Start once to begin the selected test.
      • Test 1 returns to the stored error code mode from the earlier steps.
      FixBotに聞いてみる
      コメントを追加
      • Press and hold Start/Pause for 10 seconds to reset the washer.
      • Confirm the display returns to normal operation afterward.
      FixBotに聞いてみる
      コメントを追加
      • Check for alerts such as H2O Supply when water flow is restricted or turned off.
      • Watch for a door alert if the washer does not sense a closed or locked lid.
      • If the spin light blinks, rebalance the load and inspect for out-of-balance conditions.
      • If the display shows Cancelled, close the lid and try again, or power-cycle the washer if needed.
      FixBotに聞いてみる
      コメントを追加
      • Record the stored codes and any service-test results before making repairs.
      • Future models may add more test numbers, but the basic entry steps are usually the same.
      FixBotに聞いてみる
      コメントを追加
終わりに
Use the stored codes and service tests to narrow the fault before replacing parts. Exit diagnostics when you're done and return the washer to normal operation. Repair didn't go as planned? Ask our Answers community for help.
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Ben Schlichter
メンバー登録日: 01/21/25
7,128 ポイント
224のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 25
過去 7 日: 153
過去 30 日: 790
今までの合計 9,677
