メインコンテンツにスキップ
How To Restring a Yo-Yo
必要な工具と部品
  1. How To Restring a Yo-Yo, String: 手順 1、 1の画像 1
    • Unscrew one half of the Yo-Yo from the other by twisting them in opposing directions.
  2. How To Restring a Yo-Yo: 手順 2、 1の画像 1
    • Analyze the current state of the string.
    • If the string is worn out, you must determine whether or not you want to put it back in place and keep using the Yo-Yo till the string fully breaks or replace the string right away.
    • If the string is damaged beyond repair, then get your new string ready.
  3. How To Restring a Yo-Yo: 手順 3、 1の画像 1
    • Find the end of the string that does not have a knot tied around it. This end of the string is the finger hole.
    • We are not interested in this end. You will know you have the right end if you can smoothly run a finger along the string.
  4. How To Restring a Yo-Yo: 手順 4、 1の画像 1
    • Pull at the threading, making a hole that is just big enough to fit onto the ball bearing.
    • Avoid creating a hole that is bigger than necessary, it’s good practice to do so.
  5. How To Restring a Yo-Yo: 手順 5、 1の画像 1
    • Place the hole over the bearing, allowing the string to rest on the half of the Yo-Yo with the ball bearing.
  6. How To Restring a Yo-Yo: 手順 6、 1の画像 1
    • Hold the half with the ball bearing with one hand and gently tug on the string with your other hand.
    • This will ensure that the placement of the string is secure.
  7. How To Restring a Yo-Yo: 手順 7、 1の画像 1
    • Screw the halves back together firmly, making sure that they are aligned correctly.
    • You shouldn't make the halves tighter than 'hand-tight'. This is good for you and the Yo-Yo so you won't have much trouble trying to open it up.
  8. How To Restring a Yo-Yo: 手順 8、 1の画像 1
    • Wind up your Yo-Yo and try do a trick to ensure that you’ve done a good job in restringing your Yo-Yo. Now you can enjoy your ‘Yo-Yoing’!
終わりに
After following these steps, you will have successfully restrung your Yo-Yo.
3 の人々がこのガイドを完成させました。
作成者
1人の作成者と共同作成されました。
Mark Amirthanathan
メンバー登録日: 01/19/21
205 ポイント
1ガイドが承認済み
チーム
York University, Team S1-G1, Melo-Thaiss Winter 2021 York University, Team S1-G1, Melo-Thaiss Winter 2021人のメンバー
YORK-MELO-THAISS-W21S1G1
1 メンバー
2のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 7
過去 7 日: 16
過去 30 日: 78
今までの合計 4,563
