メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Hover-1 Nomad Power Button Replacement
必要な工具と部品
    1. Hover-1 Nomad Power Button Replacement, Outer Shell: 手順 1、 3の画像 1 Hover-1 Nomad Power Button Replacement, Outer Shell: 手順 1、 3の画像 2 Hover-1 Nomad Power Button Replacement, Outer Shell: 手順 1、 3の画像 3
      • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
      • Remove the following twenty screws by rotating the screwdriver counterclockwise:
      • Eight 16.2mm Phillips #2 screws
      • Eight 15mm Phillips #2 screws
      • Four 19.1mm Phillips #2 screws
      • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
      • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
      FixBotに聞いてみる
      コメントを追加
    2. Hover-1 Nomad Power Button Replacement: 手順 2、 3の画像 1 Hover-1 Nomad Power Button Replacement: 手順 2、 3の画像 2 Hover-1 Nomad Power Button Replacement: 手順 2、 3の画像 3
      • Use a nylon spudger to pry the metal handle away from the outer shell.
      • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
      • Lift the hoverboard off the metal handle.
      • Repeat for the handle on the other side of the hoverboard.
      FixBotに聞いてみる
      コメントを追加
    3. Hover-1 Nomad Power Button Replacement: 手順 3、 1の画像 1
      • Lift the plastic cover on each side up and away from the device.
      • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
      FixBotに聞いてみる
      コメントを追加
    4. Hover-1 Nomad Power Button Replacement: 手順 4、 2の画像 1 Hover-1 Nomad Power Button Replacement: 手順 4、 2の画像 2
      • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
      • Charging port wires
      • Speaker assembly wires
      • Power button wires
      • Headlight wires
      • Only the headlight wires need to be disconnected from the other circuit board.
      • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
      FixBotに聞いてみる
      コメントを追加
    1. Hover-1 Nomad Power Button Replacement, Power Button: 手順 5、 2の画像 1 Hover-1 Nomad Power Button Replacement, Power Button: 手順 5、 2の画像 2
      • Peel off the glue around the power button.
      • Unscrew the hexagonal nut around the power button by rotating the nut counterclockwise with a pair of pliers.
      FixBotに聞いてみる
      コメントを追加
    2. Hover-1 Nomad Power Button Replacement: 手順 6、 1の画像 1
      • Feed the wire and connector through the removed nut and pull the power button out through the hole in the outer casing.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Samuel Frazee
メンバー登録日: 10/08/18
1,015 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team S15-G1, White Fall 2018 Cal Poly, Team S15-G1, White Fall 2018人のメンバー
CPSU-WHITE-F18S15G1
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 19
今までの合計 651
