メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Hover-1 Nomad Battery Replacement
必要な工具と部品
    1. Hover-1 Nomad Battery Replacement, Outer Shell: 手順 1、 3の画像 1 Hover-1 Nomad Battery Replacement, Outer Shell: 手順 1、 3の画像 2 Hover-1 Nomad Battery Replacement, Outer Shell: 手順 1、 3の画像 3
      • Break the two warranty stickers by poking a screwdriver through them or peeling them off.
      • Remove the following twenty screws by rotating the screwdriver counterclockwise:
      • Eight 16.2mm Phillips #2 screws
      • Eight 15mm Phillips #2 screws
      • Four 19.1mm Phillips #2 screws
      • The holes containing most of the screws are deep and narrow. A screwdriver with interchangable bits will not be able to reach them.
      • Do not over-tighten the screws during reassembly. Over-tightened screws can crack the plastic channels holding the shell to the frame of the hoverboard.
      FixBotに聞いてみる
      コメントを追加
    2. Hover-1 Nomad Battery Replacement: 手順 2、 3の画像 1 Hover-1 Nomad Battery Replacement: 手順 2、 3の画像 2 Hover-1 Nomad Battery Replacement: 手順 2、 3の画像 3
      • Use a nylon spudger to pry the metal handle away from the outer shell.
      • Rotate the metal handle toward the center of the hoverboard to unlock the plate from the retaining clips.
      • Lift the hoverboard off the metal handle.
      • Repeat for the handle on the other side of the hoverboard.
      FixBotに聞いてみる
      コメントを追加
    3. Hover-1 Nomad Battery Replacement: 手順 3、 1の画像 1
      • Lift the plastic cover on each side up and away from the device.
      • Multiple wires connect the circuit boards to the outer shell. Remove the shell gently to avoid damaging the wires or components.
      FixBotに聞いてみる
      コメントを追加
    4. Hover-1 Nomad Battery Replacement: 手順 4、 2の画像 1 Hover-1 Nomad Battery Replacement: 手順 4、 2の画像 2
      • Disconnect the following wires by pinching the connector tabs and pulling the plugs out of the connectors:
      • Charging port wires
      • Speaker assembly wires
      • Power button wires
      • Headlight wires
      • Only the headlight wires need to be disconnected from the other circuit board.
      • Ensure the wires are connected to the correct ports on the circuit board during reassembly.
      FixBotに聞いてみる
      コメントを追加
    1. Hover-1 Nomad Battery Replacement, Gyroscope Sensor Boards: 手順 5、 1の画像 1
      • Cut the two zip ties around the bundle of wires with cutting pliers.
      • The zip tie is secured tightly around the wires. Be careful not to nick or cut any of the wires while removing the zip tie.
      • Do not puncture or cut the lithium-ion battery. Especially with a battery this large, the battery can catch fire or explode if damaged.
      FixBotに聞いてみる
      コメントを追加
    2. Hover-1 Nomad Battery Replacement: 手順 6、 2の画像 1 Hover-1 Nomad Battery Replacement: 手順 6、 2の画像 2
      • Disconnect the circuit boards from the battery by pulling both battery connectors apart.
      FixBotに聞いてみる
      コメントを追加
    3. Hover-1 Nomad Battery Replacement: 手順 7、 3の画像 1 Hover-1 Nomad Battery Replacement: 手順 7、 3の画像 2 Hover-1 Nomad Battery Replacement: 手順 7、 3の画像 3
      • Disconnect the following wires connecting the circuit boards to the sensors and motors:
      • Disconnect the white connectors by pinching the tab and pulling up on the connectors.
      • Disconnect the black connectors by pulling the two sides apart.
      • Disconnect the green, yellow, and blue cables by pulling back the plastic shielding and pulling the ends apart.
      FixBotに聞いてみる
      コメントを追加
    4. Hover-1 Nomad Battery Replacement: 手順 8、 1の画像 1
      • Remove the four 14mm Phillips #1 screws in the corners of each circuit board by turning the screwdriver counterclockwise.
      FixBotに聞いてみる
      コメントを追加
    5. Hover-1 Nomad Battery Replacement: 手順 9、 1の画像 1
      • Remove the circuit board by pulling it up and out of the hoverboard.
      FixBotに聞いてみる
      コメントを追加
    1. Hover-1 Nomad Battery Replacement, Battery: 手順 10、 2の画像 1 Hover-1 Nomad Battery Replacement, Battery: 手順 10、 2の画像 2
      • Remove the four 15mm screws from the battery cage with a Phillips #2 screwdriver.
      FixBotに聞いてみる
      コメントを追加
    2. Hover-1 Nomad Battery Replacement: 手順 11、 2の画像 1 Hover-1 Nomad Battery Replacement: 手順 11、 2の画像 2
      • Lift the battery cage up and off the battery.
      FixBotに聞いてみる
      コメントを追加
    3. Hover-1 Nomad Battery Replacement: 手順 12、 1の画像 1
      • Remove the battery by lifting it off the hoverboard frame.
      • The battery is attached to the frame with an adhesive strip. It can be removed by hand with some force.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Samuel Frazee
メンバー登録日: 10/08/18
1,015 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team S15-G1, White Fall 2018 Cal Poly, Team S15-G1, White Fall 2018人のメンバー
CPSU-WHITE-F18S15G1
4 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 13
過去 30 日: 41
今までの合計 1,847
