メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Hott T725-8G Battery Replacement
必要な工具と部品
    1. Hott T725-8G Battery Replacement, Back Panel: 手順 1、 1の画像 1
      • Remove the back of the device using the Plastic Opening tool by placing it between the front and back panel and gently prying them apart.
      FixBotに聞いてみる
      コメントを追加
    2. Hott T725-8G Battery Replacement: 手順 2、 1の画像 1
      • Once the Plastic Opening tool has separated the halves, use your hands to pull them completely apart.
      • Be careful when doing this - the speaker is attached to the back panel and has wires running to the motherboard in the front panel.
      FixBotに聞いてみる
      コメントを追加
    3. Hott T725-8G Battery Replacement: 手順 3、 1の画像 1
      • Carefully dislodge the speaker from the back panel.
      FixBotに聞いてみる
      コメントを追加
    1. Hott T725-8G Battery Replacement, Battery: 手順 4、 1の画像 1
      • Remove the yellow tape holding the wire connecting the battery to the motherboard with your fingers.
      FixBotに聞いてみる
      コメントを追加
    2. Hott T725-8G Battery Replacement: 手順 5、 1の画像 1
      • Use your fingers to separate the ribbon wire from the battery and the back of the display.
      FixBotに聞いてみる
      コメントを追加
    3. Hott T725-8G Battery Replacement: 手順 6、 1の画像 1
      • Use your fingers to remove more yellow tape holding down the wire connecting the battery to the motherboard.
      FixBotに聞いてみる
      コメントを追加
    4. Hott T725-8G Battery Replacement: 手順 7、 1の画像 1
      • You can check one of the connection points between the battery and the motherboard to see if it is firmly connected (which it should be) using the plastic Spudger. It is not necessary to remove this wire to replace the battery.
      FixBotに聞いてみる
      コメントを追加
    5. Hott T725-8G Battery Replacement: 手順 8、 1の画像 1
      • Use a Plastic Spudger to separate the adhesive side of the battery from the back of the display.
      • Avoid using metal when working with batteries.
      • The adhesive is extremely sticky, but will separate. Ensure that the battery doesn't bend or fold while removing it.
      FixBotに聞いてみる
      コメントを追加
    6. Hott T725-8G Battery Replacement: 手順 9、 1の画像 1
      • You may use the plastic Spudger to separate the connections between the battery and motherboard. The new battery is now ready to be soldered on.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Emma Carroll
メンバー登録日: 10/20/16
220 ポイント
5のガイドは作成済み
チーム
UMass Dartmouth, Team 6-2, Martin Fall 2016 UMass Dartmouth, Team 6-2, Martin Fall 2016人のメンバー
UMASSD-MARTIN-F16S6G2
3 メンバー
11のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 30
今までの合計 695
