はじめに
If a propeller blade is damaged or isn’t operating as it should be, then it might be time to replace it, and this is the guide to do so. The propeller blade plays an essential role in the flying and redirecting of the drone. The only tool needed is a Phillips #0 screwdriver. Overall, the process is simple and doesn’t take much time to replace.
必要な工具と部品
Take your Phillips #0 screwdriver and remove the 4 mm Phillips #0 screw located on the propeller blade.
