はじめに
The air filter may need to be replaced more frequently than other parts of this device for its most optimal performance. You may notice this part needs replacing if the device begins to make a humming noise in excess or the device becomes hot when in use and may even shut itself off due to overheating.
必要な工具と部品
Begin with turning the projector on its side so the bottom of the device is clearly visible.
ある他の人がこのガイドを完成しました。
