メインコンテンツにスキップ
Heyday Wireless Speaker 8125 Charging Port Replacement
必要な工具と部品
  1. Heyday Wireless Speaker 8125 Charging Port Replacement, Grille: 手順 1、 3の画像 1 Heyday Wireless Speaker 8125 Charging Port Replacement, Grille: 手順 1、 3の画像 2 Heyday Wireless Speaker 8125 Charging Port Replacement, Grille: 手順 1、 3の画像 3
    • Orient the speaker so that it is sitting upright.
    • Use your nondominant hand to hold the speaker in place while you firmly push the plastic spudger into the seam between the device wall and the grille.
    • Push down with the plastic spudger and lift the grill until you feel it separate from the speaker.
    • Gently remove it from the top of the device.
  2. Heyday Wireless Speaker 8125 Charging Port Replacement, Black Plastic Cover: 手順 2、 2の画像 1 Heyday Wireless Speaker 8125 Charging Port Replacement, Black Plastic Cover: 手順 2、 2の画像 2
    この手順で使用する道具:
    購入する
    • Use tweezers to remove the four black rubber screw covers.
    • Use a Phillips screwdriver to remove four 8.9 mm screws underneath the screw covers.
    • Once all four screws are out, gently pull the black cover out using your hands or use a spudger to pry it out.
    • The cover is attached to the motherboard beneath by the speaker cable. Don't yank the cover from the device. You will need to detach the connector from the socket before removing it entirely.
  3. Heyday Wireless Speaker 8125 Charging Port Replacement, Motherboard: 手順 3、 3の画像 1 Heyday Wireless Speaker 8125 Charging Port Replacement, Motherboard: 手順 3、 3の画像 2 Heyday Wireless Speaker 8125 Charging Port Replacement, Motherboard: 手順 3、 3の画像 3
    • Use a Phillips screwdriver to remove four 6.6 mm screws from the motherboard.
    • Lift the motherboard out of the speaker gently.
    • It's attached below by a couple of cables, so don't pull it out.
  4. Heyday Wireless Speaker 8125 Charging Port Replacement: 手順 4、 2の画像 1 Heyday Wireless Speaker 8125 Charging Port Replacement: 手順 4、 2の画像 2
    • Pull each cable away from the connector in the same direction that the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    • Remove the motherboard from the device.
  5. Heyday Wireless Speaker 8125 Charging Port Replacement, Charging Port: 手順 5、 2の画像 1 Heyday Wireless Speaker 8125 Charging Port Replacement, Charging Port: 手順 5、 2の画像 2
    • Flip the board upside down.
    • Use a soldering iron to desolder the charging ports' solder joints.
    • Please refer to the How To Solder And Desolder Connections guide link for more information on soldering.
    • Use caution when soldering. Not only can the soldering tool harm you, but if used incorrectly, it could damage the device's motherboard as well.
    • Remove the charging port.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Ryan Butler
メンバー登録日: 01/18/23
363 ポイント
4のガイドは作成済み
チーム
Linn Benton Community College, Team 1-1, Karnes Winter 2023 Linn Benton Community College, Team 1-1, Karnes Winter 2023人のメンバー
LBCC-KARNES-W23S1G1
4 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 161
