はじめに
If you need to replace the motor of your Heyday Suitcase Turntable, follow this guide.
If the turntable does not spin when the device is on and has power, it may be because the motor is damaged or faulty and needs to be replaced.
Before beginning this repair, be sure turn the device off and unplugged from the power cord.
必要な工具と部品
この手順で使用する道具:Tweezers$3.99
Using angled tweezers or a Halberd spudger, pry the spindle shaft from the spindle.
Use a Phillips #2 screwdriver to remove the four screws on each corner of the baseboard.
