メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
必要な工具と部品
この分解は修理ガイドでは ありません。 お持ちのHeat Gunを修理する際は、iFixitの修理ガイドをご利用ください。
  1. Heat Gun Disassembly, Overall structure: 手順 1、 3の画像 1 Heat Gun Disassembly, Overall structure: 手順 1、 3の画像 2 Heat Gun Disassembly, Overall structure: 手順 1、 3の画像 3
    • All screws on one side for ease of assembly
    • Wire has a stiffener for protection
    • Switch is placed on handle in an ergonomic position so that one hand operation is easy
    • The back of the handle and the back of the body are in a straight plane in order to place the gun in vertical position after operation to cool it down
    • Vents are placed in the top part to facilitate air flow
    • The product is colored in industrial orange to be easily visible and distinguishable from the work environment
    FixBotに聞いてみる
    コメントを追加
  2. Heat Gun Disassembly, Plastic detailing: 手順 2、 3の画像 1 Heat Gun Disassembly, Plastic detailing: 手順 2、 3の画像 2 Heat Gun Disassembly, Plastic detailing: 手順 2、 3の画像 3
    • All plastic detailing is made to have no overhangs
    • screwing details are used in order to locate the two half together without external jig
    • A lip joint is used in order to secure the assembly and also make it impermeable and rigid
    FixBotに聞いてみる
    コメントを追加
  3. Heat Gun Disassembly, Electrical component placement: 手順 3、 2の画像 1 Heat Gun Disassembly, Electrical component placement: 手順 3、 2の画像 2
    • All electrical components are connected using connectors instead of direct soldering to facilitate easy replacement
    • The components have negative placers inbuilt in the in plastic injection mold
    • The electrical components are placed in order to prevent shorting
    FixBotに聞いてみる
    コメントを追加
  4. Heat Gun Disassembly, Heat component placements: 手順 4、 3の画像 1 Heat Gun Disassembly, Heat component placements: 手順 4、 3の画像 2 Heat Gun Disassembly, Heat component placements: 手順 4、 3の画像 3
    • All heat components are suspended in order to prevent the heated elements to come in contact with plastic parts
    • The blower chamber is designed in heat resistant pet in order to prevent it from deformation
    • The motor and the blower fan has a press fit
    FixBotに聞いてみる
    コメントを追加
  5. Heat Gun Disassembly, Heat tube: 手順 5、 2の画像 1 Heat Gun Disassembly, Heat tube: 手順 5、 2の画像 2
    • The heat tube is using mica support and kapton insulation
    • The external heat tube is stainless steel to prevent degradation of the tube.
    • The heat coil is used as a resistor to step down voltage for motor and hence it has a dual perpose
    • The heat coil is made of nichrome wire.
    FixBotに聞いてみる
    コメントを追加
  6. Heat Gun Disassembly, Detail assembly: 手順 6、 3の画像 1 Heat Gun Disassembly, Detail assembly: 手順 6、 3の画像 2 Heat Gun Disassembly, Detail assembly: 手順 6、 3の画像 3
    • Minimum number of screws (variety) are used and all screws are self tapping in order to eliminate the use of nuts and loose parts.
    • Assembly has location pins to align circular parts in a fixed orientation.
    • Heat rings are used in order to over heating
    FixBotに聞いてみる
    コメントを追加
作成者
3人の作成者と共同で作成されました。
varunsanghvi2000
メンバー登録日: 10/23/16
192 ポイント
1ガイドが承認済み
1件のガイドコメント
Any idea where I can get a replacement for the plastic fan? It just fell off and melted and there doesn’t seem to be any information on the net. It’s a simple part. I’ve only used the gun a half a dozen times but it’s been years since it was purchased. Your instructions were helpful.
C Richards - 返信 共有
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 15
過去 30 日: 83
今までの合計 10,209
