Have you ever had a loose wire or bad jack on your headphone? This guide will help you repair your headphone jack like a new one.
Before proceeding with the replacement, you need to be familiar with the parts as this will involve connecting the right parts with the right cables.
Cut off the old faulty headphone jack.
Use the wire strippers to strip off the outermost rubber sheathing to expose the individual cords inside.
Most headphones have 3 internal wires, sometimes 4.
Unscrew the new headphone jack casing.
Separate the wires.
If you can have it held, it will be easier for working with the soldering iron.
Begin adding solder to each of the contacts of the headphone jack.
Every so often wipe off the soldering iron on a piece of sponge/cloth.
Wipe off excess solder to keep it in good condition
Take the casing and thread it to the wire, make sure to put it right way around.
Trim excess wire. (optional)
Solder the wire to the headphone jack.
Make sure each wire goes to the right connector.
Red and white wires connect to the signal. The remaining one connects the ground connector.
このガイドを埋め込む
サイズを選択し、以下のコードをコピーして、このガイドを小さなウィジェットとしてサイト/フォーラムに埋め込みます。
プレビュー
