はじめに
This guide will display how to remove and install the back panel of the HTC Wizard 200.
必要な工具と部品
To expose the battery, remove the outer case with your fingernail.
Remove the battery by pulling the black tab.
この手順で使用する道具:Spudger$3.99
Insert the flat end of the spudger into the two notches on the back of the camera cover and pry them up.
この手順で使用する道具:T5 Torx Screwdriver$5.49
Remove the four 6 mm screws with the T5 Torx screwdriver.
