メインコンテンツにスキップ
HTC Vive Sensor Array Replacement
必要な工具と部品
  1. HTC Vive Sensor Array Replacement, Open the cable compartment: 手順 1、 3の画像 1 HTC Vive Sensor Array Replacement, Open the cable compartment: 手順 1、 3の画像 2 HTC Vive Sensor Array Replacement, Open the cable compartment: 手順 1、 3の画像 3
    • Be sure to power down and disconnect your Vive before beginning.
    • Place a finger on the top edge of the compartment cover assembly and slide the assembly toward the front of the Vive until it comes loose from the headset.
    • Lift the cover away from the headset and slide it up the cables until it's out of the way.
  2. HTC Vive Sensor Array Replacement, Unplug the HDMI cable: 手順 2、 2の画像 1 HTC Vive Sensor Array Replacement, Unplug the HDMI cable: 手順 2、 2の画像 2
    • Lift the HDMI cable straight up to unplug it from the headset.
  3. HTC Vive Sensor Array Replacement, Unplug the remaining cables: 手順 3、 3の画像 1 HTC Vive Sensor Array Replacement, Unplug the remaining cables: 手順 3、 3の画像 2 HTC Vive Sensor Array Replacement, Unplug the remaining cables: 手順 3、 3の画像 3
    • Repeat the lifting and unplugging process with the remaining USB, power, and audio cables.
  4. HTC Vive Sensor Array Replacement, Unscrew the head strap mounts: 手順 4、 2の画像 1 HTC Vive Sensor Array Replacement, Unscrew the head strap mounts: 手順 4、 2の画像 2
    • Use a T5 Torx driver to remove the two 12 mm-long screws securing the head strap mounts on either side of the headset.
    • For some devices, a T6 Torx driver may work better.
    • The mounts may fall off when the screws are removed, so be careful not to lose any parts.
  5. HTC Vive Sensor Array Replacement, Remove the head strap mounts: 手順 5、 3の画像 1 HTC Vive Sensor Array Replacement, Remove the head strap mounts: 手順 5、 3の画像 2 HTC Vive Sensor Array Replacement, Remove the head strap mounts: 手順 5、 3の画像 3
    • Remove both head strap mounts.
  6. HTC Vive Sensor Array Replacement, Remove the facerest: 手順 6、 2の画像 1 HTC Vive Sensor Array Replacement, Remove the facerest: 手順 6、 2の画像 2
    • Slide the facerest straight away from the headset to remove it.
  7. HTC Vive Sensor Array Replacement, Unscrew the outer shell: 手順 7、 3の画像 1 HTC Vive Sensor Array Replacement, Unscrew the outer shell: 手順 7、 3の画像 2 HTC Vive Sensor Array Replacement, Unscrew the outer shell: 手順 7、 3の画像 3
    この手順で使用する道具:
    • Use tweezers to remove the small stickers over the four screws securing the outer shell.
    • Use a T5 Torx driver to remove the four 3.4 mm-long screws securing the outer shell.
  8. HTC Vive Sensor Array Replacement, Remove the outer shell: 手順 8、 3の画像 1 HTC Vive Sensor Array Replacement, Remove the outer shell: 手順 8、 3の画像 2 HTC Vive Sensor Array Replacement, Remove the outer shell: 手順 8、 3の画像 3
    • Grasp the top edge of the right half of the outer shell, behind the component cover and near the seam in the center. Pull it to the right and upward, away from the headset to release the clip securing that part of the shell.
  9. HTC Vive Sensor Array Replacement: 手順 9、 2の画像 1 HTC Vive Sensor Array Replacement: 手順 9、 2の画像 2
    • Grasp the right half the outer shell and pull it to the right and toward the front of the headset in a twisting motion until you feel the clips on the front of the cover release.
  10. HTC Vive Sensor Array Replacement: 手順 10、 2の画像 1 HTC Vive Sensor Array Replacement: 手順 10、 2の画像 2
    • Slide the right side of the outer shell to the right and off of the headset.
  11. HTC Vive Sensor Array Replacement: 手順 11、 2の画像 1 HTC Vive Sensor Array Replacement: 手順 11、 2の画像 2
    • Repeat the last three steps for the left side of the outer shell and remove it.
  12. HTC Vive Sensor Array Replacement, Disconnect the sensor array cables: 手順 12、 3の画像 1 HTC Vive Sensor Array Replacement, Disconnect the sensor array cables: 手順 12、 3の画像 2 HTC Vive Sensor Array Replacement, Disconnect the sensor array cables: 手順 12、 3の画像 3
    この手順で使用する道具:
    • Use tweezers to remove the clear tape over all four of the sensor array cable connectors.
  13. HTC Vive Sensor Array Replacement: 手順 13、 3の画像 1 HTC Vive Sensor Array Replacement: 手順 13、 3の画像 2 HTC Vive Sensor Array Replacement: 手順 13、 3の画像 3
    • Use the pointed end of a spudger to flip up the small locking flap on one of the sensor array ZIF connectors.
    • Slide the cable straight out of its socket on the motherboard.
  14. HTC Vive Sensor Array Replacement: 手順 14、 3の画像 1 HTC Vive Sensor Array Replacement: 手順 14、 3の画像 2 HTC Vive Sensor Array Replacement: 手順 14、 3の画像 3
    • Repeat the previous step for the remaining three sensor array cables to disconnect the remaining cables.
  15. HTC Vive Sensor Array Replacement: 手順 15、 2の画像 1 HTC Vive Sensor Array Replacement: 手順 15、 2の画像 2
    • Use tweezers or a spudger to pry up the camera cable cover and remove it.
  16. HTC Vive Sensor Array Replacement: 手順 16、 2の画像 1 HTC Vive Sensor Array Replacement: 手順 16、 2の画像 2
    • Use the flat end of a spudger to pry the camera cable connector straight up from its socket on the motherboard.
  17. HTC Vive Sensor Array Replacement, Unscrew the sensor array: 手順 17、 1の画像 1
    • Use a PH000 driver to remove the five 3.9 mm screws securing the sensor array.
  18. HTC Vive Sensor Array Replacement: 手順 18、 1の画像 1
    • Use a PH000 driver to remove the four 3.9 mm screws securing the sensor array.
  19. HTC Vive Sensor Array Replacement: 手順 19、 2の画像 1 HTC Vive Sensor Array Replacement: 手順 19、 2の画像 2
    この手順で使用する道具:
    Phillips #000 Screwdriver
    $5.49
    • You'll need a narrow, long-shaft driver to reach these screws.
  20. HTC Vive Sensor Array Replacement, Remove the sensor array: 手順 20、 2の画像 1 HTC Vive Sensor Array Replacement, Remove the sensor array: 手順 20、 2の画像 2
    • Lift the sensor array away from the headset to remove it.
終わりに
3 の人々がこのガイドを完成させました。
作成者
8人の作成者と共同で作成されました。
Adam O'Camb
メンバー登録日: 04/11/15
217,580 ポイント
416のガイドは作成済み
1件のガイドコメント
Herzlichen Dank für diese ausführliche Anleitung! Sie war sehr hilfreich und hat mir vermutlich eine Menge Zeit erspart!
Holger - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 9
過去 30 日: 35
今までの合計 3,581
