メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HTC Incredible 2 Power Button Replacement
必要な工具と部品
  1. HTC Incredible 2 Power Button Replacement, Disassembling HTC Incredible 2 Back Panel: 手順 1、 2の画像 1 HTC Incredible 2 Power Button Replacement, Disassembling HTC Incredible 2 Back Panel: 手順 1、 2の画像 2
    • Press your thumbnail into the slot between the rear panel and the front casing located on the bottom of the phone. Use a penny or dime if you have trouble using your thumbnail.
    • With a moderate amount of force, pry the rear panel up and away from the phone. You may need to slide your thumbnail up the crack to separate the rear panel from the front casing.
    • This can take a little bit of effort. Don't be discouraged if you can't get it right away.
    FixBotに聞いてみる
    コメントを追加
  2. HTC Incredible 2 Power Button Replacement: 手順 2、 1の画像 1
    • Remove the rear panel from the phone.
    FixBotに聞いてみる
    コメントを追加
  3. HTC Incredible 2 Power Button Replacement, Battery: 手順 3、 1の画像 1
    • Press your fingernail into the slot between the battery and the rear inner frame, located between the battery and LED lights.
    • Use a penny or dime if you can't use your fingernail.
    FixBotに聞いてみる
    コメントを追加
  4. HTC Incredible 2 Power Button Replacement: 手順 4、 2の画像 1 HTC Incredible 2 Power Button Replacement: 手順 4、 2の画像 2
    • Gently lever the battery up and away from the lights.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
    FixBotに聞いてみる
    コメントを追加
  5. HTC Incredible 2 Power Button Replacement, SIM Card: 手順 5、 2の画像 1 HTC Incredible 2 Power Button Replacement, SIM Card: 手順 5、 2の画像 2
    • Apply pressure with your fingertip to the pressure clip beneath the SIM card.
    • While keeping pressure on the clip, use another finger to gently slide the SIM card down over the clip.
    FixBotに聞いてみる
    コメントを追加
  6. HTC Incredible 2 Power Button Replacement: 手順 6、 2の画像 1 HTC Incredible 2 Power Button Replacement: 手順 6、 2の画像 2
    • Keep sliding SIM card until completely free from holding apparatus. Now remove the SIM card.
    FixBotに聞いてみる
    コメントを追加
  7. HTC Incredible 2 Power Button Replacement, Mid Panel: 手順 7、 1の画像 1
    • Remove the seven 1.42 mm Torx T5 screws
    FixBotに聞いてみる
    コメントを追加
  8. HTC Incredible 2 Power Button Replacement: 手順 8、 2の画像 1 HTC Incredible 2 Power Button Replacement: 手順 8、 2の画像 2
    • Use a plastic opening tool to run along the phone's side and lever mid panel upward.
    • Apply minimal pressure as the mid panel is very delicate.
    FixBotに聞いてみる
    コメントを追加
  9. HTC Incredible 2 Power Button Replacement: 手順 9、 1の画像 1
    • Gently grasp and carefully lift mid panel up and away from the device with your fingers.
    FixBotに聞いてみる
    コメントを追加
  10. HTC Incredible 2 Power Button Replacement, Power Button: 手順 10、 3の画像 1 HTC Incredible 2 Power Button Replacement, Power Button: 手順 10、 3の画像 2 HTC Incredible 2 Power Button Replacement, Power Button: 手順 10、 3の画像 3
    • Firmly grasp the power button, located on the upper right corner of the mid panel, and gently lift it up and off the mid panel.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Cristian Suarez
メンバー登録日: 04/22/14
108 ポイント
1ガイドが承認済み
チーム
Cal Poly, Team 11-53, Amido Spring 2014 Cal Poly, Team 11-53, Amido Spring 2014人のメンバー
CPSU-AMIDO-S14S11G53
5 メンバー
28のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 18
今までの合計 1,092
