メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HTC Droid DNA Rear-Facing Camera Replacement
必要な工具と部品
  1. HTC Droid DNA Rear-Facing Camera Replacement, Remove the SIM Card Tray: 手順 1、 1の画像 1
    • Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
    FixBotに聞いてみる
    コメントを追加
  2. HTC Droid DNA Rear-Facing Camera Replacement, Removing the SIM Card Tray: 手順 2、 2の画像 1 HTC Droid DNA Rear-Facing Camera Replacement, Removing the SIM Card Tray: 手順 2、 2の画像 2
    • Pull out the SIM Card Tray with your fingers.
    FixBotに聞いてみる
    コメントを追加
  3. HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Phone Casing: 手順 3、 2の画像 1 HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Phone Casing: 手順 3、 2の画像 2
    • Make sure the USB cover on the bottom of the phone is removed first.
    • Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
    • Take your time. A lot of force is necessary to loosen the front panel.
    FixBotに聞いてみる
    コメントを追加
  4. HTC Droid DNA Rear-Facing Camera Replacement, Pull the Casing Apart: 手順 4、 1の画像 1
    • Slowly pull the panel apart from the back of the phone.
    • Apply a moderate force to pry the panel from the back of the phone.
    FixBotに聞いてみる
    コメントを追加
  5. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Black Tape: 手順 5、 1の画像 1
    • Set the device down so that the bottom of the phone is facing to the right.
    • Gently take off the piece of black tape surrounding the motherboard.
    • Be careful not to rip the tape.
    FixBotに聞いてみる
    コメントを追加
  6. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Yellow Tape: 手順 6、 1の画像 1
    この手順で使用する道具:
    • Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
    FixBotに聞いてみる
    コメントを追加
  7. HTC Droid DNA Rear-Facing Camera Replacement: 手順 7、 1の画像 1
    • Rotate your phone 90 degrees clockwise so the bottom of the phone is facing you.
    • Use the T5 Torx screwdriver to remove the two 4mm screws located at the bottom of the phone.
    FixBotに聞いてみる
    コメントを追加
  8. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Void Screw: 手順 8、 1の画像 1
    • Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
    FixBotに聞いてみる
    コメントを追加
  9. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Screw Retaining Bracket: 手順 9、 1の画像 1
    • Rotate your phone back 90 Degrees counter-clockwise.
    • Use your tweezers to take off the small metal retaining bracket on the bottom right of the phone.
    FixBotに聞いてみる
    コメントを追加
  10. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Connector Screws: 手順 10、 1の画像 1
    • Remove the following Phillips #000 screws from the motherboard:
    • Four 1.6 mm screws
    • Two 1.5 mm screws
    FixBotに聞いてみる
    コメントを追加
  11. HTC Droid DNA Rear-Facing Camera Replacement, Unfasten the Connectors: 手順 11、 2の画像 1 HTC Droid DNA Rear-Facing Camera Replacement, Unfasten the Connectors: 手順 11、 2の画像 2
    • Use your pry tool to unfasten the connectors on both sides of the motherboard.
    • The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
    FixBotに聞いてみる
    コメントを追加
  12. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Yellow Tape: 手順 12、 1の画像 1
    • Use your tweezers to remove the two pieces of yellow tape shown.
    FixBotに聞いてみる
    コメントを追加
  13. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 手順 13、 2の画像 1 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 手順 13、 2の画像 2
    • Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
    FixBotに聞いてみる
    コメントを追加
  14. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Connector: 手順 14、 1の画像 1
    • Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cable of the Connector.
    FixBotに聞いてみる
    コメントを追加
  15. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 手順 15、 2の画像 1 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 手順 15、 2の画像 2
    • Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
    FixBotに聞いてみる
    コメントを追加
  16. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Connector: 手順 16、 1の画像 1
    • Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cables for the Connector.
    FixBotに聞いてみる
    コメントを追加
  17. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 手順 17、 2の画像 1 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the White Board: 手順 17、 2の画像 2
    • Rotate the phone 180 degrees.
    • Use your tweezers to gently snap up the white board on the top left of the motherboard.
    FixBotに聞いてみる
    コメントを追加
  18. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Connector: 手順 18、 1の画像 1
    • Use your tweezers to disconnect the cable on the top left of the motherboard.
    FixBotに聞いてみる
    コメントを追加
  19. HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the Black Board: 手順 19、 2の画像 1 HTC Droid DNA Rear-Facing Camera Replacement, Flipping up the Black Board: 手順 19、 2の画像 2
    • Use your tweezers to gently snap up the black board on the top left of the motherboard.
    FixBotに聞いてみる
    コメントを追加
  20. HTC Droid DNA Rear-Facing Camera Replacement, Disconnect the Small Ribbon Connector: 手順 20、 1の画像 1
    • Use your tweezers to gently remove the yellow connector on the top left of the phone.
    FixBotに聞いてみる
    コメントを追加
  21. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Black Wire: 手順 21、 1の画像 1
    • Remove the long black wire on the left of the motherboard.
    FixBotに聞いてみる
    コメントを追加
  22. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Two Black Wires: 手順 22、 1の画像 1
    • Reorient the phone so that the green camera board is farthest from you.
    • Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
    FixBotに聞いてみる
    コメントを追加
  23. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Screws: 手順 23、 1の画像 1
    • Use a Phillips #000 screwdriver to remove the two 3.9mm screws on top of motherboard.
    FixBotに聞いてみる
    コメントを追加
  24. HTC Droid DNA Rear-Facing Camera Replacement, Remove the Motherboard: 手順 24、 2の画像 1 HTC Droid DNA Rear-Facing Camera Replacement, Remove the Motherboard: 手順 24、 2の画像 2
    • Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
    FixBotに聞いてみる
    コメントを追加
  25. HTC Droid DNA Rear-Facing Camera Replacement, Remove Screws: 手順 25、 1の画像 1
    • Use a Phillips #000 screwdriver to remove the two 2.1mm screws on the top of the camera board.
    FixBotに聞いてみる
    コメントを追加
  26. HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Adhesive: 手順 26、 2の画像 1 HTC Droid DNA Rear-Facing Camera Replacement, Loosen the Adhesive: 手順 26、 2の画像 2
    • Use the pry tool along the bottom and sides of the camera board to loosen the adhesive.
    • The power button and headphone jack need to be carefully removed with the camera board or they could snap off of the camera board.
    FixBotに聞いてみる
    コメントを追加
  27. HTC Droid DNA Rear-Facing Camera Replacement, Remove Camera Board: 手順 27、 1の画像 1
    • Slowly lift the camera board up and work on removing the remaining adhesive. You can then take the camera board off of the phone.
    FixBotに聞いてみる
    コメントを追加
  28. HTC Droid DNA Rear-Facing Camera Replacement, Remove Yellow Tape: 手順 28、 2の画像 1 HTC Droid DNA Rear-Facing Camera Replacement, Remove Yellow Tape: 手順 28、 2の画像 2
    この手順で使用する道具:
    • Use your tweezers to gently pull off the two pieces of yellow tape in the center of the camera board.
    FixBotに聞いてみる
    コメントを追加
  29. HTC Droid DNA Rear-Facing Camera Replacement, White Connector Clip: 手順 29、 2の画像 1 HTC Droid DNA Rear-Facing Camera Replacement, White Connector Clip: 手順 29、 2の画像 2
    • Use your tweezers to gently flip the white connector board into the upright position.
    FixBotに聞いてみる
    コメントを追加
  30. HTC Droid DNA Rear-Facing Camera Replacement, Remove Rear-Facing Camera: 手順 30、 1の画像 1
    • Use your tweezers to remove the rear-facing camera from the camera board.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Adrian Williams
メンバー登録日: 10/14/14
585 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 4-43, Amido Fall 2014 Cal Poly, Team 4-43, Amido Fall 2014人のメンバー
CPSU-AMIDO-F14S4G43
4 メンバー
28のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 21
今までの合計 1,347
