メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Stream 13-c002dx Wireless Card Replacement
必要な工具と部品
    1. HP Stream 13-c002dx Wireless Card  Replacement, Keyboard: 手順 1、 2の画像 1 HP Stream 13-c002dx Wireless Card  Replacement, Keyboard: 手順 1、 2の画像 2
      • Begin by placing your laptop on a clean surface such as a table and away from any liquids which may spill and damage components.
      • Flip the laptop over so the bottom is facing up.
      • Use your Phillips #0 screwdriver to remove the eleven visible 5 mm screws on the back of the laptop.
      • There are some screws underneath the rubber feet. Use a spudger to remove them and gain access.
      • Unscrew the two remaining 2.5mm screws. Keep these screws separate from the first eleven 5mm screws.
      FixBotに聞いてみる
      コメントを追加
    2. HP Stream 13-c002dx Wireless Card  Replacement: 手順 2、 3の画像 1 HP Stream 13-c002dx Wireless Card  Replacement: 手順 2、 3の画像 2 HP Stream 13-c002dx Wireless Card  Replacement: 手順 2、 3の画像 3
      • Flip the laptop back over so it's right side up and open the screen.
      • Using a spudger, separate the keyboard surface from the bottom of the laptop.
      • While lifting the keyboard surface from the bottom, you will notice three cables still attaching them together. Gently unplug each of these cables from the motherboard.
      • Remove the keyboard assembly.
      FixBotに聞いてみる
      コメントを追加
    1. HP Stream 13-c002dx Wireless Card  Replacement, Wireless Card: 手順 3、 3の画像 1 HP Stream 13-c002dx Wireless Card  Replacement, Wireless Card: 手順 3、 3の画像 2 HP Stream 13-c002dx Wireless Card  Replacement, Wireless Card: 手順 3、 3の画像 3
      • Inside the laptop you will notice the wireless card located in the upper middle. This will be what you are replacing.
      • Attached to the Wi-Fi card is a black wire that must be removed. Using your hand, lift gently on the wire as close as you can to where it connects to the Wi-Fi card.
      • Once the wire is removed, set it aside so it does not get damaged.
      FixBotに聞いてみる
      コメントを追加
    2. HP Stream 13-c002dx Wireless Card  Replacement: 手順 4、 3の画像 1 HP Stream 13-c002dx Wireless Card  Replacement: 手順 4、 3の画像 2 HP Stream 13-c002dx Wireless Card  Replacement: 手順 4、 3の画像 3
      • Remove the screw holding the wireless card in place.
      • With the screw removed, gently pull back the Wi-Fi card and then lift it out of the laptop. You are now ready to insert the new wireless card.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
8人の作成者と共同で作成されました。
Hailee McCraw
メンバー登録日: 01/23/18
221 ポイント
1ガイドが承認済み
チーム
Western Carolina University, Team S1-G1, Virtue Spring 2018 Western Carolina University, Team S1-G1, Virtue Spring 2018人のメンバー
WCU-VIRTUE-S18S1G1
4 メンバー
57のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 32
今までの合計 1,832
