メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Stream 11-d010nr Webcam Replacement
必要な工具と部品
  1. HP Stream 11-d010nr Webcam Replacement, Pry out the inserts: 手順 1、 2の画像 1 HP Stream 11-d010nr Webcam Replacement, Pry out the inserts: 手順 1、 2の画像 2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
    • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
    FixBotに聞いてみる
    コメントを追加
  2. HP Stream 11-d010nr Webcam Replacement, Unscrew the back cover: 手順 2、 1の画像 1
    • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
    • Keep the screws in a safe place for reassembly.
    FixBotに聞いてみる
    コメントを追加
  3. HP Stream 11-d010nr Webcam Replacement, Pry the keyboard casing up: 手順 3、 2の画像 1 HP Stream 11-d010nr Webcam Replacement, Pry the keyboard casing up: 手順 3、 2の画像 2
    • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
    FixBotに聞いてみる
    コメントを追加
  4. HP Stream 11-d010nr Webcam Replacement, Identify the connectors: 手順 4、 1の画像 1
    • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
    • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
    FixBotに聞いてみる
    コメントを追加
  5. HP Stream 11-d010nr Webcam Replacement, Disconnect the cables: 手順 5、 3の画像 1 HP Stream 11-d010nr Webcam Replacement, Disconnect the cables: 手順 5、 3の画像 2 HP Stream 11-d010nr Webcam Replacement, Disconnect the cables: 手順 5、 3の画像 3
    • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
    • Carefully disconnect the three ribbon cables.
    FixBotに聞いてみる
    コメントを追加
  6. HP Stream 11-d010nr Webcam Replacement, Lift the keyboard out: 手順 6、 1の画像 1
    • Gently lift the keyboard out of the laptop to fully detach it from the device.
    • While handling, avoid damaging any remaining components.
    FixBotに聞いてみる
    コメントを追加
  7. HP Stream 11-d010nr Webcam Replacement, Battery: 手順 7、 1の画像 1
    • Remove any tape holding the battery connector in place.
    • Using your fingers, carefully unplug the battery.
    FixBotに聞いてみる
    コメントを追加
  8. HP Stream 11-d010nr Webcam Replacement: 手順 8、 2の画像 1 HP Stream 11-d010nr Webcam Replacement: 手順 8、 2の画像 2
    • Remove the four 3mm #000 Phillips screws holding the battery in place.
    • Carefully lift the battery out of the laptop.
    FixBotに聞いてみる
    コメントを追加
  9. HP Stream 11-d010nr Webcam Replacement, Wifi Chip: 手順 9、 2の画像 1 HP Stream 11-d010nr Webcam Replacement, Wifi Chip: 手順 9、 2の画像 2
    • Unplug the black wire attached to the wireless chip.
    FixBotに聞いてみる
    コメントを追加
  10. HP Stream 11-d010nr Webcam Replacement: 手順 10、 2の画像 1 HP Stream 11-d010nr Webcam Replacement: 手順 10、 2の画像 2
    • Remove the one 3mm Phillips #000 screw holding the wireless chip in place.
    • Lift the wireless chip up and out.
    FixBotに聞いてみる
    コメントを追加
  11. HP Stream 11-d010nr Webcam Replacement, Webcam: 手順 11、 3の画像 1 HP Stream 11-d010nr Webcam Replacement, Webcam: 手順 11、 3の画像 2 HP Stream 11-d010nr Webcam Replacement, Webcam: 手順 11、 3の画像 3
    • Flip up the flap and unplug the display cord from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  12. HP Stream 11-d010nr Webcam Replacement: 手順 12、 2の画像 1 HP Stream 11-d010nr Webcam Replacement: 手順 12、 2の画像 2
    • Using a JIS #1 screwdriver, remove the four 2.2 mm screws holding monitor to body.
    FixBotに聞いてみる
    コメントを追加
  13. HP Stream 11-d010nr Webcam Replacement: 手順 13、 1の画像 1
    この手順で使用する道具:
    • Use tweezers to remove the screw covers from the lid.
    • Unscrew the two 2.2 mm #000 Phillips screws.
    FixBotに聞いてみる
    コメントを追加
  14. HP Stream 11-d010nr Webcam Replacement: 手順 14、 1の画像 1
    • Open the upper lid with the iFixit opening tool.
    FixBotに聞いてみる
    コメントを追加
  15. HP Stream 11-d010nr Webcam Replacement: 手順 15、 2の画像 1 HP Stream 11-d010nr Webcam Replacement: 手順 15、 2の画像 2
    • Disconnect the webcam cord using tweezers.
    • Remove the webcam using tweezers.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Zachary Heisler
メンバー登録日: 01/24/19
382 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S1-G3, White Winter 2019 Cal Poly, Team S1-G3, White Winter 2019人のメンバー
CPSU-WHITE-W19S1G3
4 メンバー
11のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 35
今までの合計 704
