メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Stream 11-d010nr Battery Replacement
必要な工具と部品
  1. HP Stream 11-d010nr Battery Replacement, Pry out the inserts: 手順 1、 2の画像 1 HP Stream 11-d010nr Battery Replacement, Pry out the inserts: 手順 1、 2の画像 2
    • Unplug and turn off the HP Stream 11 before disassembling the device.
    • Using a spudger, gently pry off the two elliptical rubber inserts located in the top corners.
    • Carefully remove the two circular rubber inserts positioned beneath the removed elliptical inserts.
    FixBotに聞いてみる
    コメントを追加
  2. HP Stream 11-d010nr Battery Replacement, Unscrew the back cover: 手順 2、 1の画像 1
    • Using a Phillips #1 screwdriver, remove the eleven 5.6 mm screws securing the back cover.
    • Keep the screws in a safe place for reassembly.
    FixBotに聞いてみる
    コメントを追加
  3. HP Stream 11-d010nr Battery Replacement, Pry the keyboard casing up: 手順 3、 2の画像 1 HP Stream 11-d010nr Battery Replacement, Pry the keyboard casing up: 手順 3、 2の画像 2
    • Using an iFixit opening tool, carefully pry open the case to separate the keyboard from the main body. Work slowly to avoid damaging the edges.
    • HP Stream 11s tend to be really difficult to open. If your device is not opening with a standard iFixit opening tool, use a nylon spudger, then the metal spudger, or a metal Jimmy as the last resort.
    • When using the metal spudger or Jimmy, be careful not to bring these tools into contact with any electronic components of the device as this can damage the device.
    FixBotに聞いてみる
    コメントを追加
  4. HP Stream 11-d010nr Battery Replacement, Identify the connectors: 手順 4、 1の画像 1
    • Carefully lift the keyboard and identify the three ribbon cables connecting the main body of the laptop to the keyboard.
    • Lift the keyboard with extreme care to avoid damaging the delicate ribbon cables. Applying excessive force can easily tear or break them easily.
    FixBotに聞いてみる
    コメントを追加
  5. HP Stream 11-d010nr Battery Replacement, Disconnect the cables: 手順 5、 3の画像 1 HP Stream 11-d010nr Battery Replacement, Disconnect the cables: 手順 5、 3の画像 2 HP Stream 11-d010nr Battery Replacement, Disconnect the cables: 手順 5、 3の画像 3
    • Using a spudger, gently lift the flaps on the ZIF connectors to release the three ribbon cables securely attached to them.
    • Carefully disconnect the three ribbon cables.
    FixBotに聞いてみる
    コメントを追加
  6. HP Stream 11-d010nr Battery Replacement, Lift the keyboard out: 手順 6、 1の画像 1
    • Gently lift the keyboard out of the laptop to fully detach it from the device.
    • While handling, avoid damaging any remaining components.
    FixBotに聞いてみる
    コメントを追加
  7. HP Stream 11-d010nr Battery Replacement, Battery: 手順 7、 1の画像 1
    • Remove any tape holding the battery connector in place.
    • Using your fingers, carefully unplug the battery.
    FixBotに聞いてみる
    コメントを追加
  8. HP Stream 11-d010nr Battery Replacement: 手順 8、 2の画像 1 HP Stream 11-d010nr Battery Replacement: 手順 8、 2の画像 2
    • Remove the four 3mm #000 Phillips screws holding the battery in place.
    • Carefully lift the battery out of the laptop.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Zachary Heisler
メンバー登録日: 01/24/19
382 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S1-G3, White Winter 2019 Cal Poly, Team S1-G3, White Winter 2019人のメンバー
CPSU-WHITE-W19S1G3
4 メンバー
11のガイドは作成済み
3件のガイドコメント
HP lists the screws on the back cover as size pm1.9x5.6. What is wrong with HP that they would use such an odd size? I tried 2x6mm and they seem to work fine.
Greg Worrel - 返信 共有
Me podrias ayudar con el numero de serie del boton de encendido
sam Carrizales - 返信 共有
O donde lo puedo conseguir
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 60
今までの合計 3,565
