メインコンテンツにスキップ
HP Spectre x360 15-bl012dx Display Assembly
必要な工具と部品
  1. HP Spectre x360 15-bl012dx Display Assembly, Battery Replacement: 手順 1、 2の画像 1 HP Spectre x360 15-bl012dx Display Assembly, Battery Replacement: 手順 1、 2の画像 2
    • Power off the device before beginning disassembly.
    • Place the computer so that the back panel is facing up. Begin by removing the two visible Torx T5 9 mm screws near the hinges.
    • Next, remove the four visible Torx T5 3 mm on the sides.
    • Keep track of all screws.
  2. HP Spectre x360 15-bl012dx Display Assembly: 手順 2、 3の画像 1 HP Spectre x360 15-bl012dx Display Assembly: 手順 2、 3の画像 2 HP Spectre x360 15-bl012dx Display Assembly: 手順 2、 3の画像 3
    • Please note the upper two feet are already removed. The device was given to us this way.
    • Remove the two upper feet using an opening tool or spudger if they are still in place. The upper feet are closer to the hinges for the screen.
    • Remove the two 8 mm Phillips #1 screws under the feet.
    • These are the final screws to remove from the back panel. In total, you should remove eight screws between Steps 1 and 2.
  3. HP Spectre x360 15-bl012dx Display Assembly: 手順 3、 1の画像 1
    • Use a spudger to pry the back panel off of the laptop. Work your way around the perimeter of the device to loosen the connection.
    • Take the back panel off of the laptop.
  4. HP Spectre x360 15-bl012dx Display Assembly: 手順 4、 1の画像 1
    • Use a Phillips #1 screwdriver to remove six 4 mm screws securing the battery.
  5. HP Spectre x360 15-bl012dx Display Assembly: 手順 5、 3の画像 1 HP Spectre x360 15-bl012dx Display Assembly: 手順 5、 3の画像 2 HP Spectre x360 15-bl012dx Display Assembly: 手順 5、 3の画像 3
    • Unplug the battery connector located on the motherboard.
    • Remove the battery from the laptop.
  6. HP Spectre x360 15-bl012dx Display Assembly, Solid State Drive (SSD): 手順 6、 3の画像 1 HP Spectre x360 15-bl012dx Display Assembly, Solid State Drive (SSD): 手順 6、 3の画像 2 HP Spectre x360 15-bl012dx Display Assembly, Solid State Drive (SSD): 手順 6、 3の画像 3
    • Using minimal force, lift the locking bars on the USB board ZIF connector using a plastic opening tool or fingernail and pull out the ribbon cable.
  7. HP Spectre x360 15-bl012dx Display Assembly: 手順 7、 1の画像 1
    • Using your fingers, remove the USB ribbon cable from the motherboard above the fan.
  8. HP Spectre x360 15-bl012dx Display Assembly: 手順 8、 2の画像 1 HP Spectre x360 15-bl012dx Display Assembly: 手順 8、 2の画像 2
    • Remove the 3 mm Phillips #1 screw that secures the solid state drive to the board.
    • Please note this laptop was not supplied with an SSD, so this is not the same SSD you will find in your device.
  9. HP Spectre x360 15-bl012dx Display Assembly: 手順 9、 1の画像 1
    • Slide the SSD card out of the connection at a 45 degree angle so that the SSD teeth are not bent.
  10. HP Spectre x360 15-bl012dx Display Assembly, Motherboard: 手順 10、 2の画像 1 HP Spectre x360 15-bl012dx Display Assembly, Motherboard: 手順 10、 2の画像 2
    • Use a Phillips #1 screwdriver to remove two 3 mm screws from each fan.
  11. HP Spectre x360 15-bl012dx Display Assembly: 手順 11、 2の画像 1 HP Spectre x360 15-bl012dx Display Assembly: 手順 11、 2の画像 2
    • Remove the six 2.5 mm Phillips #1 screws holding the heat sink in.
  12. HP Spectre x360 15-bl012dx Display Assembly: 手順 12、 2の画像 1 HP Spectre x360 15-bl012dx Display Assembly: 手順 12、 2の画像 2
    • Pop up the eight tabs on all the ZIF connectors on the motherboard. This can either be done with a spudger or your finger nail.
    • Looking at the back of the laptop, there are two ZIF connectors in the top right (one should already be disconnected from the SSD removal), one in the top left, and 5 on the bottom. Indicated by red squares.
  13. HP Spectre x360 15-bl012dx Display Assembly: 手順 13、 3の画像 1 HP Spectre x360 15-bl012dx Display Assembly: 手順 13、 3の画像 2 HP Spectre x360 15-bl012dx Display Assembly: 手順 13、 3の画像 3
    • Remove the five remaining connectors from the motherboard. Two on the bottom left, one on the bottom right, and one on the top right. These connectors pull up off the motherboard with no clips.
  14. HP Spectre x360 15-bl012dx Display Assembly: 手順 14、 2の画像 1 HP Spectre x360 15-bl012dx Display Assembly: 手順 14、 2の画像 2
    • Use a Phillips #1 screwdriver to remove the 2 mm screw from the Wi-Fi card that secures it to the motherboard.
    • Slide the Wi-Fi card out of the slot.
  15. HP Spectre x360 15-bl012dx Display Assembly: 手順 15、 3の画像 1 HP Spectre x360 15-bl012dx Display Assembly: 手順 15、 3の画像 2 HP Spectre x360 15-bl012dx Display Assembly: 手順 15、 3の画像 3
    • Snake the speaker wires out of the plastic routings on the fans that hold the wires in place.
    • Lift the fans and heat sink out.
    • Remove the black heat shield under the heat sink.
  16. HP Spectre x360 15-bl012dx Display Assembly: 手順 16、 3の画像 1 HP Spectre x360 15-bl012dx Display Assembly: 手順 16、 3の画像 2 HP Spectre x360 15-bl012dx Display Assembly: 手順 16、 3の画像 3
    • Clean the old thermal paste off of the heat sink, cpu, and gpu using isopropyl alcohol and a paper towel. The higher the percentage of the alcohol, the better. I used 91%.
    • Remember to apply thermal paste before installing the new motherboard with fresh thermal paste! A pea sized amount is plenty.
  17. HP Spectre x360 15-bl012dx Display Assembly: 手順 17、 2の画像 1 HP Spectre x360 15-bl012dx Display Assembly: 手順 17、 2の画像 2
    • Using a Phillips #1 screwdriver, remove four screws from the motherboard.
    • Two 3 mm screws
    • Two 2 mm screws
  18. HP Spectre x360 15-bl012dx Display Assembly: 手順 18、 1の画像 1
    • Remove the motherboard. Pull up the right side first, then pull it out.
  19. HP Spectre x360 15-bl012dx Display Assembly, Display Assembly and Camera: 手順 19、 2の画像 1 HP Spectre x360 15-bl012dx Display Assembly, Display Assembly and Camera: 手順 19、 2の画像 2
    • Open the laptop so the screen is facing you.
    • Using a Phillips #1 screwdriver, remove two 5 mm screws from each hinge.
  20. HP Spectre x360 15-bl012dx Display Assembly: 手順 20、 1の画像 1
    • Remove the display assembly by pulling the hinges out of the body.
    • This should not require much effort so make sure not to pull too hard. The cables will come out with the display assembly.
    • The camera and screen are one piece and must be replaced together.
終わりに
ある他の人がこのガイドを完成しました。
作成者
4人の作成者と共同で作成されました。
Cade Caldwell
メンバー登録日: 02/22/22
202 ポイント
2のガイドは作成済み
チーム
Clemson, Team 1-1, Hunter Spring 2022 Clemson, Team 1-1, Hunter Spring 2022人のメンバー
CLEM-HUNTER-S22S1G1
5 メンバー
5のガイドは作成済み
1 Guide Comment
en mi caso tuve que usar una secadora de pelo para darle calor a las partes de cinta "doble pega" y aun asi, me di cuenta una vez desensamblada la pantalla que la pantalla touch y la de video venian tambien pegadas de la misma manera y esta segunda parte no se explica en este video.
Alvaro Velasco - 返信
コメントを追加
統計データ:
過去 24時間: 3
過去 7 日: 14
過去 30 日: 28
今までの合計 2,069
