メインコンテンツにスキップ
HP Spectre 13 4003dx x360 Touchpad Replacement
必要な工具と部品
  1. HP Spectre 13 4003dx x360 Touchpad Replacement, Battery: 手順 1、 2の画像 1 HP Spectre 13 4003dx x360 Touchpad Replacement, Battery: 手順 1、 2の画像 2
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    購入する
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Turn the computer upside down.
    • Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
    • Make sure to use the magnetic project mat to help you keep track of the small screws.
  2. HP Spectre 13 4003dx x360 Touchpad Replacement: 手順 2、 2の画像 1 HP Spectre 13 4003dx x360 Touchpad Replacement: 手順 2、 2の画像 2
    • Use an opening tool to pry up and loosen the back case from the laptop.
    • If the back case doesn't loosen easily, there may be screws hidden underneath the rubber feet. Carefully pry a foot up and remove any hidden screws.
    • Remove the back case.
  3. HP Spectre 13 4003dx x360 Touchpad Replacement: 手順 3、 2の画像 1 HP Spectre 13 4003dx x360 Touchpad Replacement: 手順 3、 2の画像 2
    • Remove the four 2mm Phillips #00 screws securing the battery.
    • The screw locations are marked by small white arrows on the battery.
  4. HP Spectre 13 4003dx x360 Touchpad Replacement: 手順 4、 3の画像 1 HP Spectre 13 4003dx x360 Touchpad Replacement: 手順 4、 3の画像 2 HP Spectre 13 4003dx x360 Touchpad Replacement: 手順 4、 3の画像 3
    • Peel off the adhesive on the left side of the battery holding the speaker wire down.
    • Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
    • Carefully unplug the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the battery.
    • It is normal for your battery to flex and bend a bit where the wider section meets the narrower section.
  5. HP Spectre 13 4003dx x360 Touchpad Replacement, Touchpad: 手順 5、 2の画像 1 HP Spectre 13 4003dx x360 Touchpad Replacement, Touchpad: 手順 5、 2の画像 2
    • Using a plastic opening tool, lift the locking bar on the trackpad ZIF connector.
    • Gently pull the cable out.
  6. HP Spectre 13 4003dx x360 Touchpad Replacement: 手順 6、 3の画像 1 HP Spectre 13 4003dx x360 Touchpad Replacement: 手順 6、 3の画像 2 HP Spectre 13 4003dx x360 Touchpad Replacement: 手順 6、 3の画像 3
    • Using the PH00 Screwdriver, remove the five 2.0 mm screws indicated in the picture.
  7. HP Spectre 13 4003dx x360 Touchpad Replacement: 手順 7、 2の画像 1 HP Spectre 13 4003dx x360 Touchpad Replacement: 手順 7、 2の画像 2
    • Using a plastic opening tool, carefully lift up on the lower center metal piece of the touchpad.
    • Using both hands, gently lift up on the touchpad until it is completely removed.
    • If you are uncomfortable using the plastic opening tool, both hands can be used to remove the touchpad.
終わりに
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Ethan Plumer
メンバー登録日: 01/29/18
605 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team S5-G4, Passmore Spring 2018 USF Tampa, Team S5-G4, Passmore Spring 2018人のメンバー
USFT-PASSMORE-S18S5G4
3 メンバー
8のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 12
過去 30 日: 32
今までの合計 3,875
