メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Spectre 13 4003dx x360 Display Assembly Replacement
必要な工具と部品
  1. HP Spectre 13 4003dx x360 Display Assembly Replacement, Battery: 手順 1、 2の画像 1 HP Spectre 13 4003dx x360 Display Assembly Replacement, Battery: 手順 1、 2の画像 2
    この手順で使用する道具:
    Magnetic Project Mat
    $19.95
    • Before you begin, be sure to turn off your laptop and discharge the battery down to 25%.
    • Turn the computer upside down.
    • Use the T5 Torx Screwdriver to remove the eight 3.3 mm screws.
    • Make sure to use the magnetic project mat to help you keep track of the small screws.
  2. HP Spectre 13 4003dx x360 Display Assembly Replacement: 手順 2、 2の画像 1 HP Spectre 13 4003dx x360 Display Assembly Replacement: 手順 2、 2の画像 2
    • Use an opening tool to pry up and loosen the back case from the laptop.
    • If the back case doesn't loosen easily, there may be screws hidden underneath the rubber feet. Carefully pry a foot up and remove any hidden screws.
    • Remove the back case.
  3. HP Spectre 13 4003dx x360 Display Assembly Replacement: 手順 3、 2の画像 1 HP Spectre 13 4003dx x360 Display Assembly Replacement: 手順 3、 2の画像 2
    • Remove the four 2mm Phillips #00 screws securing the battery.
    • The screw locations are marked by small white arrows on the battery.
  4. HP Spectre 13 4003dx x360 Display Assembly Replacement: 手順 4、 3の画像 1 HP Spectre 13 4003dx x360 Display Assembly Replacement: 手順 4、 3の画像 2 HP Spectre 13 4003dx x360 Display Assembly Replacement: 手順 4、 3の画像 3
    • Peel off the adhesive on the left side of the battery holding the speaker wire down.
    • Move the battery slightly to gain access to the battery plug, located on the left edge of the battery.
    • Carefully unplug the battery by pulling the connector towards the battery.
    • Pull parallel to the battery, not straight up.
    • Remove the battery.
    • It is normal for your battery to flex and bend a bit where the wider section meets the narrower section.
  5. HP Spectre 13 4003dx x360 Display Assembly Replacement, Display Assembly: 手順 5、 3の画像 1 HP Spectre 13 4003dx x360 Display Assembly Replacement, Display Assembly: 手順 5、 3の画像 2 HP Spectre 13 4003dx x360 Display Assembly Replacement, Display Assembly: 手順 5、 3の画像 3
    • Remove the two 2mm Phillips #00 screws from the fan.
    • Disconnect the fan from the motherboard.
  6. HP Spectre 13 4003dx x360 Display Assembly Replacement: 手順 6、 3の画像 1 HP Spectre 13 4003dx x360 Display Assembly Replacement: 手順 6、 3の画像 2 HP Spectre 13 4003dx x360 Display Assembly Replacement: 手順 6、 3の画像 3
    • Using minimal force, disconnect both WiFi antennae cables.
    • Remove the single Phillips #00 screw that secures the WiFi card.
    • Slide the WiFi card up until it is completely removed.
    • Do not pull up on the wireless module while it is still seated. You may inadvertently damage it.
  7. HP Spectre 13 4003dx x360 Display Assembly Replacement: 手順 7、 2の画像 1 HP Spectre 13 4003dx x360 Display Assembly Replacement: 手順 7、 2の画像 2
    • Remove the four hinge screw with a Phillips #00 screwdriver.
  8. HP Spectre 13 4003dx x360 Display Assembly Replacement: 手順 8、 2の画像 1 HP Spectre 13 4003dx x360 Display Assembly Replacement: 手順 8、 2の画像 2
    • Grip the black tape and pull up to unplug.
  9. HP Spectre 13 4003dx x360 Display Assembly Replacement: 手順 9、 1の画像 1
    • Separate the display assembly from the body of the computer.
    • As a result of the orientation of the hinges, you may need to rotate open the laptop to around 270 degrees to clear them.
終わりに
7 の人々がこのガイドを完成させました。
作成者
3人の作成者と共同で作成されました。
Ethan Plumer
メンバー登録日: 01/29/18
611 ポイント
2のガイドは作成済み
チーム
USF Tampa, Team S5-G4, Passmore Spring 2018 USF Tampa, Team S5-G4, Passmore Spring 2018人のメンバー
USFT-PASSMORE-S18S5G4
3 メンバー
8のガイドは作成済み
2件のガイドコメント
You forgot to mention that some people may have to remove the heatsink like I did before the screen will come off.
Wargaming Super Noob - 返信
Anyone have any tips on reconnecting the WIFI antennas? I finally gave up and just decided to get a USB dongle… worked out well otherwise. I did also have to remove the heatsink like Wargaming Super Noob mentioned.
David Bergeron - 返信
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 47
今までの合計 10,629
