メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP ProBook 640 G5 RAM Replacement
必要な工具と部品
    1. HP ProBook 640 G5 RAM Replacement, Back Cover: 手順 1、 1の画像 1
      • Always make sure the HP ProBook 640 G5 is completely powered off and unplugged before beginning this repair. Attempting to open the laptop while it has power may cause electrical damage or personal injury.
      • Shut down the HP ProBook 640 G5 completely.
      • Disconnect the power adapter and all connected peripherals.
      • Press and hold the power button for 5 seconds to discharge remaining electricity.
      FixBotに聞いてみる
      コメントを追加
    2. HP ProBook 640 G5 RAM Replacement: 手順 2、 1の画像 1
      • Flip the laptop over so the bottom is facing up.
      • Loosen eight silver 6mm screws using a Phillips #0 screwdriver.
      • These screws are captive, so they will loosen but remain attached to the cover.
      • Remove two black 6mm screws using a TR7 Torx screwdriver.
      • Insert a plastic opening tool into the seam and gently pry around the edges.
      • Lift the bottom cover away from the laptop.
      FixBotに聞いてみる
      コメントを追加
    1. HP ProBook 640 G5 RAM Replacement, RAM: 手順 3、 1の画像 1
      • When replacing RAM, avoid touching the gold contacts and black chips. Handle the stick only by its outer edges or plastic/metal shielding. Touching the chips or gold contacts can introduce static electricity or oil from your fingers, potentially causing damage or poor connectivity.
      • Locate the RAM you intend on replacing/upgrading.
      • Some laptops may come with two sticks of RAM; the one we are working on is equipped with only one.
      FixBotに聞いてみる
      コメントを追加
    2. HP ProBook 640 G5 RAM Replacement: 手順 4、 1の画像 1
      • Gently push outward on the two retaining clips on each side of the module.
      • The RAM stick will pop up at a 30-degree angle.
      • Hold the RAM module by the edges (avoid touching the gold contacts).
      • Slide it out of the slot at the same angle it popped up.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Eric Olivarez
メンバー登録日: 02/23/26
449 ポイント
4のガイドは作成済み
チーム
Austin Community College, Team 1-2, Anderson Spring 2026 Austin Community College, Team 1-2, Anderson Spring 2026人のメンバー
AUSTINCC-ANDERSON-S26S1G2
3 メンバー
6のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 7
過去 30 日: 26
今までの合計 155
