はじめに
The keyboard is one of the most frequently used components on a HP ProBook 640 G5 laptop, and issues such as stuck keys, water damage, non-responsive sections, or complete failure are common reasons for replacement. This guide will walk you through the full replacement process, including safely disconnecting the battery, accessing the keyboard ribbon cables, removing the top cover, and installing the new keyboard. Before beginning this repair, power off the laptop and disconnect all power sources.
必要な工具と部品
Shut down the HP ProBook 640 G5 completely.
Disconnect the power adapter and all connected peripherals.
Press and hold the power button for 5 seconds to discharge remaining electricity.
Lift the rear edge of the keyboard up gently making sure not to rip or tug on the cable connectors.
Disconnect in order as pictured:
Disconnect the keyboard backlight ribbon cable from the system board.
Disconnect the point stick ribbon cable from the system board.
Disconnect the keyboard ribbon cable from the system board.
