メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Photosmart D110a Scanner Glass Replacement
必要な工具と部品
    1. HP Photosmart D110a Scanner Glass Replacement, Printer Hood Assembly: 手順 1、 1の画像 1
      • Pull down both front panels to open the printer. Lift the scanner flap upward by pulling down on it; there are two mouth pieces that need to be pulled down.
      • Adjust the flap covering the scanner upward, as shown.
      FixBotに聞いてみる
      コメントを追加
    2. HP Photosmart D110a Scanner Glass Replacement: 手順 2、 1の画像 1
      • Pull the scanner flap gently away from the printer to release its two clips.
      FixBotに聞いてみる
      コメントを追加
    3. HP Photosmart D110a Scanner Glass Replacement: 手順 3、 1の画像 1
      • Locate the three screws on top of the printer.
      • The orange circle shows a fourth screw located behind the power panel. Ignore this one for now, as directions to remove this screw are in Step 5.
      FixBotに聞いてみる
      コメントを追加
    4. HP Photosmart D110a Scanner Glass Replacement: 手順 4、 3の画像 1 HP Photosmart D110a Scanner Glass Replacement: 手順 4、 3の画像 2 HP Photosmart D110a Scanner Glass Replacement: 手順 4、 3の画像 3
      • Using a T-9 screwdriver, remove the three screws from the printer's top.
      FixBotに聞いてみる
      コメントを追加
    5. HP Photosmart D110a Scanner Glass Replacement: 手順 5、 2の画像 1 HP Photosmart D110a Scanner Glass Replacement: 手順 5、 2の画像 2
      • To remove the power button panel:
      • Reach inside the printer's front opening.
      • Press the small clip behind the power button.
      • A picture of the power button panel removed is provided to show the location of the clip that needs to be pressed.
      • Pull the panel out from right to left.
      FixBotに聞いてみる
      コメントを追加
    6. HP Photosmart D110a Scanner Glass Replacement: 手順 6、 2の画像 1 HP Photosmart D110a Scanner Glass Replacement: 手順 6、 2の画像 2
      • Remove the fourth screw, which was covered by the power button panel.
      • Do not try and torque the screw from an angle. This will ruin the screw's head, and make it even more difficult to remove the screw. Only remove it as already described.
      • This screw is placed awkwardly. We found holding a T9 bit in a pair of needle nose pliers gave us enough leverage to pull it up.
      FixBotに聞いてみる
      コメントを追加
    7. HP Photosmart D110a Scanner Glass Replacement: 手順 7、 3の画像 1 HP Photosmart D110a Scanner Glass Replacement: 手順 7、 3の画像 2 HP Photosmart D110a Scanner Glass Replacement: 手順 7、 3の画像 3
      • With a partner's help:
      • Have one person lift the hood 2-3 inches.
      • Have the other person disconnect the three cables from the motherboard (the green PCB) to the hood by gently pulling upward on them.
      • Remove the hood completely.
      FixBotに聞いてみる
      コメントを追加
    1. HP Photosmart D110a Scanner Glass Replacement, Printer Hood: 手順 8、 3の画像 1 HP Photosmart D110a Scanner Glass Replacement, Printer Hood: 手順 8、 3の画像 2 HP Photosmart D110a Scanner Glass Replacement, Printer Hood: 手順 8、 3の画像 3
      • Remove the single T-9 screw from the hood's underside, as shown.
      FixBotに聞いてみる
      コメントを追加
    2. HP Photosmart D110a Scanner Glass Replacement: 手順 9、 2の画像 1 HP Photosmart D110a Scanner Glass Replacement: 手順 9、 2の画像 2
      • With the screw removed, separate the two pieces of the hood by lifting it vertically.
      • Only lift the the top piece enough so that there is no tension applied to the ribbon cables shown.
      • Carefully pull down the white ribbon cable through the top piece of the hood.
      FixBotに聞いてみる
      コメントを追加
    3. HP Photosmart D110a Scanner Glass Replacement: 手順 10、 2の画像 1 HP Photosmart D110a Scanner Glass Replacement: 手順 10、 2の画像 2
      • Separate the hood pieces while keeping the black ribbon cable connected. Rest the scanner piece carefully to avoid stressing its ribbon cable.
      FixBotに聞いてみる
      コメントを追加
    1. HP Photosmart D110a Scanner Glass Replacement, Scanner Glass: 手順 11、 2の画像 1 HP Photosmart D110a Scanner Glass Replacement, Scanner Glass: 手順 11、 2の画像 2
      • The scanner glass is held down by one T-9 screw. Use a screw driver to remove the screw.
      FixBotに聞いてみる
      コメントを追加
    2. HP Photosmart D110a Scanner Glass Replacement: 手順 12、 2の画像 1 HP Photosmart D110a Scanner Glass Replacement: 手順 12、 2の画像 2
      • Once the screw has been taken out, lift the glass covering from the bottom left corner as shown.
      • The other corner of the glass can now be lifted up as well. Use the two corners to lift up the whole scanner glass.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
4 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Tim Wise
メンバー登録日: 04/01/11
173 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 10-38, Forte Spring 2011 Cal Poly, Team 10-38, Forte Spring 2011人のメンバー
CPSU-FORTE-S11S10G38
5 メンバー
20のガイドは作成済み
5件のガイドコメント
Very helpful guide, the scanner glass was dirty from inside, so the guide was able to give me clear instructions how to proceed with the openning. Thanks!
Alexandre Silva - 返信 共有
Very helpful in most ways. I needed to clean the inside of the glass because the ribbon cable was leaving a discoloration when traveling and showed up on my scanned documents. I actually did this solo and was fine until reassemble faze when the actual scanner bar would not stay in place to reassemble the two parts. I finally got it back together after much profanity and no small amount of patients. The next dilemma was the reassembly of top to bottom which was easily fixed with a small piece of duct tape holding The right side in place while reconnecting the two ribbon cables and the power connector. All is back together and working fine. My thanx to my God and to you for a successful fix.
keith mcguire - 返信 共有
I found that it was actually a T10 bit on mine as well and found when removing the 3 screws shown in red a 2” bit works best but with the one marked in orange under the power button a 1” if placed in the screw first then pulled forward slightly I was able to use a 1/4” drive screwdriver on a slight angle which made it much faster to remove that one screw. That being said, still a very helpful fix to a problem that was really frustrating me as I kept cleaning the top of the glass until I realized the problem was on the underside.
As an after thought, if it were me I would have designed the scanner portion so that less effort would be needed to clean both sides of the glass like screws or clips that can be accessed just by lifting the door on the top.
These instructions are very good and I was able to do this with my husbands help. With one except it doesn’t mention if the new scanner glass has a right side or a wrong side to it. Does it matter at all which side goes up and which side goes down?
Thank you
Bonnie
Yvonne Nielsen - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 27
今までの合計 6,714
