メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Photosmart D110a Power Button Replacement
必要な工具と部品
    1. HP Photosmart D110a Power Button Replacement, Power Button: 手順 1、 1の画像 1
      • Open the printer's mouth by pulling the two mouth pieces down.
      • Lift the flap covering the scanner. When you are finished, the printer should appear as shown.
      FixBotに聞いてみる
      コメントを追加
    2. HP Photosmart D110a Power Button Replacement: 手順 2、 1の画像 1
      • Remove the flap for the scanner by pulling lightly on the clip that attaches it to the printer.
      • The clip may be damaged by applying too much force.
      FixBotに聞いてみる
      コメントを追加
    3. HP Photosmart D110a Power Button Replacement: 手順 3、 3の画像 1 HP Photosmart D110a Power Button Replacement: 手順 3、 3の画像 2 HP Photosmart D110a Power Button Replacement: 手順 3、 3の画像 3
      • Remove the three screws from the top of the printer using a T9 screwdriver as shown.
      • The screws are located in the far-left, far-right, and near-right corners of the printer, with respect to the front view.
      FixBotに聞いてみる
      コメントを追加
    4. HP Photosmart D110a Power Button Replacement: 手順 4、 1の画像 1
      • Reach into the mouth of the printer and press the clip behind the power button to release the power button face.
      FixBotに聞いてみる
      コメントを追加
    5. HP Photosmart D110a Power Button Replacement: 手順 5、 1の画像 1
      • A picture of the removed power button is provided to show the location of the clip that needs to be pressed.
      • After pressing the clip, pull out the face of the power button by sliding it from the right to the left side.
      FixBotに聞いてみる
      コメントを追加
    6. HP Photosmart D110a Power Button Replacement: 手順 6、 3の画像 1 HP Photosmart D110a Power Button Replacement: 手順 6、 3の画像 2 HP Photosmart D110a Power Button Replacement: 手順 6、 3の画像 3
      • The power button face has a plastic holder that attaches the power button and the wireless button to the face plate using two slots.
      • Loosen the plastic holder by pulling the slots on the face plate away from the plastic holder.
      • Remove the plastic holder from the face plate after the slots are loosened.
      FixBotに聞いてみる
      コメントを追加
    7. HP Photosmart D110a Power Button Replacement: 手順 7、 3の画像 1 HP Photosmart D110a Power Button Replacement: 手順 7、 3の画像 2 HP Photosmart D110a Power Button Replacement: 手順 7、 3の画像 3
      • The plastic holder secures the power button by two slots.
      • Using a spudger, push the holders inward to detach the button from the plastic holder.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
12人の作成者と共同で作成されました。
Tim Wise
メンバー登録日: 04/01/11
173 ポイント
7のガイドは作成済み
チーム
Cal Poly, Team 10-38, Forte Spring 2011 Cal Poly, Team 10-38, Forte Spring 2011人のメンバー
CPSU-FORTE-S11S10G38
5 メンバー
10のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 36
今までの合計 4,096
