メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Pavilion DV2160BR Keyboard Replacement
必要な工具と部品
    1. HP Pavilion DV2160BR Keyboard Replacement, Battery: 手順 1、 1の画像 1
      • Start with the bottom of the laptop facing up.
      FixBotに聞いてみる
      コメントを追加
    2. HP Pavilion DV2160BR Keyboard Replacement: 手順 2、 2の画像 1 HP Pavilion DV2160BR Keyboard Replacement: 手順 2、 2の画像 2
      • Locate the battery compartment at the rear of the device.
      • There is a slider button located under the left side of the battery compartment. It is indicated by a battery symbol. Move the slider to the left and lift the battery out.
      FixBotに聞いてみる
      コメントを追加
    1. HP Pavilion DV2160BR Keyboard Replacement, Keyboard: 手順 3、 3の画像 1 HP Pavilion DV2160BR Keyboard Replacement, Keyboard: 手順 3、 3の画像 2 HP Pavilion DV2160BR Keyboard Replacement, Keyboard: 手順 3、 3の画像 3
      • Unscrew the 5 screws along the top edge of the laptop’s back panel and inside the battery compartment.
      • The two screws inside the battery compartment are 5 mm Phillips #1.
      • The three screws outside the battery compartment are 9 mm Phillips #1.
      FixBotに聞いてみる
      コメントを追加
    2. HP Pavilion DV2160BR Keyboard Replacement: 手順 4、 3の画像 1 HP Pavilion DV2160BR Keyboard Replacement: 手順 4、 3の画像 2 HP Pavilion DV2160BR Keyboard Replacement: 手順 4、 3の画像 3
      • Remove the three 6 mm Phillips #1 screws that are marked by a keyboard symbol. These screws are holding in the keyboard itself.
      FixBotに聞いてみる
      コメントを追加
    3. HP Pavilion DV2160BR Keyboard Replacement: 手順 5、 1の画像 1
      • Flip the laptop over and open the lid.
      FixBotに聞いてみる
      コメントを追加
    4. HP Pavilion DV2160BR Keyboard Replacement: 手順 6、 1の画像 1
      • Using a blue plastic opening tool, remove the bezel by sliding the tool along the edges.
      • The bezel is held in place by plastic tabs, which you will hear snapping out of place as you slide the plastic opener tool.
      • You don't need to take the bezel all the way off the device, and shouldn't since it it connected to the laptop by two cables.
      FixBotに聞いてみる
      コメントを追加
    5. HP Pavilion DV2160BR Keyboard Replacement: 手順 7、 1の画像 1
      • Lift the keyboard from the device, starting from the top sides and pulling it away from the bottom end gently.
      • The keyboard is still connected by a cable, so do not pull it too quickly as it could become damaged.
      FixBotに聞いてみる
      コメントを追加
    6. HP Pavilion DV2160BR Keyboard Replacement: 手順 8、 1の画像 1
      • Remove the old keyboard by gently unplugging the ribbon cable
      • Prepare the new keyboard and connect it to the laptop via the ribbon cable
      • After reconnecting the ribbon cable, ensure it is securely fastened and the connector is properly locked.
      • Carefully reassemble the keyboard into its housing, making sure all tabs are aligned. Reattach the back panel and screws, then power on the laptop to test the new keyboard.
      • Confirm that all keys are functioning correctly and the keyboard is securely in place.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
7人の作成者と共同で作成されました。
Shannon
メンバー登録日: 04/11/13
55 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 13-66, Johann Spring 2013 Cal Poly, Team 13-66, Johann Spring 2013人のメンバー
CPSU-JOHANN-S13S13G66
3 メンバー
68のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 5
過去 7 日: 21
過去 30 日: 59
今までの合計 1,283
