この修理ガイドは変更されています。最新の未承認バージョンに切り替えます。
はじめに
This guide will help you replace your power adapter inside the printer.
必要な工具と部品
Turn off the printer and remove the power cable.
Remove two 13mm T9 screws using a T9-Torx screwdriver. Turn counterclockwise until the screws are released.
Remove two screws 13mm screws with a T9-Torx screwdriver by rotating them counterclockwise.
