メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Envy dv7 Hard Drive Replacement
必要な工具と部品
  1. HP Envy dv7 Hard Drive  Replacement, Hard Drive: 手順 1、 1の画像 1
    • Slide the switch shown in the circle above and remove the battery from its housing. No screws are required to remove this part, and the battery should come out with little to no effort.
    FixBotに聞いてみる
    コメントを追加
  2. HP Envy dv7 Hard Drive  Replacement: 手順 2、 1の画像 1
    • After removing the battery, find the center screw and unscrew it using a #1 Phillips head screwdriver until it will not unscrew any further.
    • This screw is not supposed to come out, so do not be frustrated when you are not able to take it out.
    FixBotに聞いてみる
    コメントを追加
  3. HP Envy dv7 Hard Drive  Replacement: 手順 3、 1の画像 1
    • After undoing the center screw, the back cover will be able to slide off of the computer and you will have access to the inside.
    FixBotに聞いてみる
    コメントを追加
  4. HP Envy dv7 Hard Drive  Replacement: 手順 4、 1の画像 1
    • To unfasten the hard drive's casing, there are two 3mm screws that you need to undo circled above. These screws require a Phillips #1 screwdriver.
    FixBotに聞いてみる
    コメントを追加
  5. HP Envy dv7 Hard Drive  Replacement: 手順 5、 1の画像 1
    • After the screws are removed, the casing will slide to the left and then up. Make sure that the cable that connects it to the computer is as intact as possible.
    FixBotに聞いてみる
    コメントを追加
  6. HP Envy dv7 Hard Drive  Replacement: 手順 6、 2の画像 1 HP Envy dv7 Hard Drive  Replacement: 手順 6、 2の画像 2
    • To gain access to the actual hard drive, there are two screws located on either long side of the casing that need to be undone. These screws are 3mm long and require a Phillips #1 Screwdriver to undo.
    FixBotに聞いてみる
    コメントを追加
  7. HP Envy dv7 Hard Drive  Replacement: 手順 7、 1の画像 1
    • After the screws around the casing are removed, the casing will slide off opposite to the connector. From here, grip the connector that is connected to the hard drive and gently pull to remove it.
    • From here, you are free to implement whatever hard drive unit you want to, just make sure to verify that the hard drive is compatible with your computer.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
2人の作成者と共同で作成されました。
Rayvin Rainer
メンバー登録日: 02/07/17
120 ポイント
1ガイドが承認済み
チーム
Central Coast New Tech High, Team 6-7, Rushing Spring 2017 Central Coast New Tech High, Team 6-7, Rushing Spring 2017人のメンバー
CCNTH-RUSHING-S17S6G7
2 メンバー
1のガイドは作成済み
1件のガイドコメント
I am looking for a hdd replacement with Windows 10 or 11 on it for my HP ENVY DV7 The present drive has Win 8 bout it’s not coming up
Yes Child - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 23
今までの合計 2,084
