メインコンテンツにスキップ
HP EliteBook x360 1030 G3 Battery Replacement
必要な工具と部品
  1. HP EliteBook x360 1030 G3 Battery Replacement, Bottom Cover: 手順 1、 1の画像 1
    • Be sure to power off and unplug your device before you begin your repair.
    • Close the laptop and flip it so that the screen is on the surface of the table and the back plate is facing you.
    • Remove the 3.3 mm screw near the top of the hinge using a T5 Torx screwdriver.
    • Remove the remaining four 7.3 mm screws using the same screwdriver.
  2. HP EliteBook x360 1030 G3 Battery Replacement: 手順 2、 1の画像 1
    • Separate the bottom cover from the laptop, starting from the upper corner and working your way around the edge.
    • The plastic fastening may make cracking sounds when separating, but this is normal.
  3. HP EliteBook x360 1030 G3 Battery Replacement, Battery: 手順 3、 1の画像 1
    • Remove the five 3.7 mm screws that are holding the battery in place using a Phillips #00 screwdriver.
    • Be sure to keep the screws organized because they will be reused for the next battery installation.
  4. HP EliteBook x360 1030 G3 Battery Replacement: 手順 4、 2の画像 1 HP EliteBook x360 1030 G3 Battery Replacement: 手順 4、 2の画像 2
    • Carefully pull the white plastic battery connector towards you until it is removed from the port.
    • Be sure not to pull using the wires; doing so may cause damage.
  5. HP EliteBook x360 1030 G3 Battery Replacement: 手順 5、 1の画像 1
    • Gently lift the battery out of its place.
終わりに
8 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Pablo Arriola
メンバー登録日: 04/22/19
504 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team S2-G9, Maness Spring 2019 Cal Poly, Team S2-G9, Maness Spring 2019人のメンバー
CPSU-MANESS-S19S2G9
4 メンバー
16のガイドは作成済み
4 件のコメント
Thanks, it is very useful.
Mohamed Wafi Aljunaedi - 返信
Looks easy and do you know if the pc can work without battery, only with charger?
Sam Uel - 返信
Thank you. very useful.
mustapha ELABED - 返信
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 31
過去 30 日: 149
今までの合計 11,916
