メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP EliteBook 1050 G1 Key Replacement
必要な工具と部品
    1. HP EliteBook 1050 G1 Key Replacement, Key: 手順 1、 1の画像 1
      • Find the broken or malfunctioning key on the keyboard.
      • In this guide, we will replace the "ctrl" key, but this guide works for all keys on the keyboard.
      FixBotに聞いてみる
      コメントを追加
    2. HP EliteBook 1050 G1 Key Replacement: 手順 2、 2の画像 1 HP EliteBook 1050 G1 Key Replacement: 手順 2、 2の画像 2
      • Wedge the spudger under the corner of the key and pry up while moving the spudger along the length of one edge of the key.
      • Repeat this process for three sides of the key you are removing.
      • No matter how gently you attempt to remove the key, it will sound like it is breaking when you pry and remove it from its housing. THIS IS OKAY. The plastic brackets HP uses to keep its keys in place are very loud, but also very durable.
      FixBotに聞いてみる
      コメントを追加
    3. HP EliteBook 1050 G1 Key Replacement: 手順 3、 1の画像 1
      • Lift the key manually by the the edge opposite the one side of the key you did not pry off with the spudger.
      • To ensure the easiest possible removal, lift the key up while gently pulling away from the edge that is still in the keyboard.
      FixBotに聞いてみる
      コメントを追加
    4. HP EliteBook 1050 G1 Key Replacement: 手順 4、 1の画像 1
      • To replace the key, lay the new key over its housing with the proper orientation and push it down until you hear a click.
      • If the key is not broken, just "sticky" or malfunctioning, procced up to this step. You can now wiggle the white silicon portion of the key's interior around, pushing down on the extended part of the silicon and wiggling it back and forth. Once you have done that, you can replace the key as described above.
      • Furthermore, you can remove any debris from under the keys at this time with a toothpick or a dampened q-tip, which may improve the performance of your keys.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Jacob Osecheck
メンバー登録日: 04/15/19
279 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S2-G10, Maness Spring 2019 Cal Poly, Team S2-G10, Maness Spring 2019人のメンバー
CPSU-MANESS-S19S2G10
4 メンバー
17のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 12
過去 7 日: 44
過去 30 日: 183
今までの合計 9,882
