メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP Compaq nc8430 Fan Replacement
必要な工具と部品
    1. HP Compaq nc8430 Fan Replacement, Battery: 手順 1、 1の画像 1
      • Completely shut down the device and unplug any adapters and cords connected to the device.
      • Carefully flip the device over so that the bottom is facing up.
      • Slide both of the latches to the left.
      FixBotに聞いてみる
      コメントを追加
    2. HP Compaq nc8430 Fan Replacement: 手順 2、 1の画像 1
      • Slide up against the three lines the battery has.
      FixBotに聞いてみる
      コメントを追加
    3. HP Compaq nc8430 Fan Replacement: 手順 3、 1の画像 1
      • Slide the battery up and away from the laptop.
      • Slowly remove the battery to prevent any connectors from getting damaged.
      FixBotに聞いてみる
      コメントを追加
    1. HP Compaq nc8430 Fan Replacement, Fan: 手順 4、 1の画像 1
      • Use a J1 screwdriver to remove each screw on the bottom of the computer. This will allow for the opening of the laptop to gain access to the fan.
      FixBotに聞いてみる
      コメントを追加
    2. HP Compaq nc8430 Fan Replacement: 手順 5、 1の画像 1
      • Now that you have unscrewed most of the bottom of the laptop, carefully flip it back over.
      • Press down firmly on the four latches shown in the photo to detach the key board. This will unlock the latches holding the keyboard down, doing this will grant you access to the inside of the computer.
      FixBotに聞いてみる
      コメントを追加
    3. HP Compaq nc8430 Fan Replacement: 手順 6、 2の画像 1 HP Compaq nc8430 Fan Replacement: 手順 6、 2の画像 2
      • Remove the keyboard carefully now that it is detached, and use the pry tool to assist you in the removal of the keyboard.
      FixBotに聞いてみる
      コメントを追加
    4. HP Compaq nc8430 Fan Replacement: 手順 7、 1の画像 1
      • Now your laptop should have no screws and no keyboard.
      • You should now be able to open up the base of the laptop. With a bit of force, detach the sides latches of the base by pulling them open carefully.
      • Your computer should now look like the provided photo, where you can see where the fan is located.
      FixBotに聞いてみる
      コメントを追加
    5. HP Compaq nc8430 Fan Replacement: 手順 8、 2の画像 1 HP Compaq nc8430 Fan Replacement: 手順 8、 2の画像 2
      • Carefully remove fan by detaching the blue and white plug from the main socket.
      • Continue to unscrew all screws to completely disassemble to gain complete access to the computer's fan.
      FixBotに聞いてみる
      コメントを追加
    6. HP Compaq nc8430 Fan Replacement: 手順 9、 1の画像 1
      • As an extra precaution, please check for any dirt or debris that are preventing the fans complete functionality.
      • Use a cotton swab and alcohol to clean the fan before re attaching it to ensure smooth functioning of the fan.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Andrea Funes
メンバー登録日: 03/22/17
149 ポイント
1ガイドが承認済み
チーム
Texas Tech, Team S13-G4, Bennett Spring 2017 Texas Tech, Team S13-G4, Bennett Spring 2017人のメンバー
TTU-BENNETT-S17S13G4
5 メンバー
52のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 6
過去 7 日: 27
過去 30 日: 105
今までの合計 1,808
