メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HP 15-R263DX USB Port Replacement
必要な工具と部品
  1. HP 15-R263DX USB Port Replacement, Battery: 手順 1、 2の画像 1 HP 15-R263DX USB Port Replacement, Battery: 手順 1、 2の画像 2
    • Eject the battery from the computer by sliding the two clips on the bottom of the computer toward the center of the computer.
    • Slide the battery out as shown in the picture.
  2. HP 15-R263DX USB Port Replacement, Optical Drive: 手順 2、 2の画像 1 HP 15-R263DX USB Port Replacement, Optical Drive: 手順 2、 2の画像 2
    • Using a Phillips #1 screwdriver, remove the small screw next to the disc engraving shown in the picture.
  3. HP 15-R263DX USB Port Replacement: 手順 3、 1の画像 1
    • Gently slide the optical drive out of the side of the computer.
  4. HP 15-R263DX USB Port Replacement, HP 15-R263DX Disassembly: 手順 4、 2の画像 1 HP 15-R263DX USB Port Replacement, HP 15-R263DX Disassembly: 手順 4、 2の画像 2
    • Locate the two corner grips on the hinge side of the computer.
    • Using a metal spudger, remove the two corner grips to reveal the screws.
  5. HP 15-R263DX USB Port Replacement: 手順 5、 1の画像 1
    • Remove the 11 small screws on the bottom of the computer that are shown in the picture.
  6. HP 15-R263DX USB Port Replacement: 手順 6、 1の画像 1
    • Remove the 2 small screws that are on the bottom side of the disc tray slot.
    • These screws are shorter and wider than the others.
  7. HP 15-R263DX USB Port Replacement: 手順 7、 2の画像 1 HP 15-R263DX USB Port Replacement: 手順 7、 2の画像 2
    • Once the keyboard is loose, do not immediately pull away from computer. It is attached by the ribbon connector.
    • Using a spudger, pry around the edges of the keyboard until all clips are disengaged and the keyboard is loose from the computer.
    • To disconnect the ribbon connector, flip up the black clip shown in the picture.
    • Gently pull the ribbon until disconnected.
  8. HP 15-R263DX USB Port Replacement: 手順 8、 2の画像 1 HP 15-R263DX USB Port Replacement: 手順 8、 2の画像 2
    • Disconnect the other two ribbon connectors underneath the keyboard by fliping up the black clips.
    • Remove the 4 small screws shown in the picture.
  9. HP 15-R263DX USB Port Replacement: 手順 9、 1の画像 1
    • Disengage the face plate clips by prying the case away from around the outer edge of the face plate with a metal wedge.
    • The face plate can then be lifted away from the computer.
  10. HP 15-R263DX USB Port Replacement, Hard Drive: 手順 10、 1の画像 1
    • Remove the 2 black screws holding the hard drive to the computer frame.
  11. HP 15-R263DX USB Port Replacement: 手順 11、 2の画像 1 HP 15-R263DX USB Port Replacement: 手順 11、 2の画像 2
    • Gently slide the hard drive away from the motherboard to disconnect it.
    • After it's disconnected, lift the hard drive up to remove it from the computer.
  12. HP 15-R263DX USB Port Replacement, USB Port: 手順 12、 1の画像 1
    • Remove the single screw holding the USB ports and chip into the computer.
  13. HP 15-R263DX USB Port Replacement: 手順 13、 1の画像 1
    • Remove the chip by gently pulling it up and then away from the edge of the case.
  14. HP 15-R263DX USB Port Replacement: 手順 14、 1の画像 1
    • Under the motherboard, disconnect the wire that runs to the USB chip.
    • You may need to pull or wedge the wire up from the case as a section of it is glued down.
終わりに
作成者
3人の作成者と共同で作成されました。
Drake Hort
メンバー登録日: 03/05/18
487 ポイント
3のガイドは作成済み
チーム
Washington State, Team S2-G3, Lobnitz Spring 2018 Washington State, Team S2-G3, Lobnitz Spring 2018人のメンバー
WSU-LOBNITZ-S18S2G3
8 メンバー
7のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 12
過去 30 日: 44
今までの合計 699
