メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
HMDX Jam Rubber Battery Cover Replacement
必要な工具と部品
  1. HMDX Jam Rubber Battery Cover Replacement, Rubber Base: 手順 1、 1の画像 1
    • Pry off the rubber cover at the bottom of the speaker by using the plastic opening tool.
    FixBotに聞いてみる
    コメントを追加
  2. HMDX Jam Rubber Battery Cover Replacement: 手順 2、 1の画像 1
    • Slowly peel the rubber cover off.
    FixBotに聞いてみる
    コメントを追加
  3. HMDX Jam Rubber Battery Cover Replacement: 手順 3、 1の画像 1
    • After completely removing the rubber cover, find a new cover and prepare both it and the device for attachment.
    FixBotに聞いてみる
    コメントを追加
  4. HMDX Jam Rubber Battery Cover Replacement: 手順 4、 1の画像 1
    • Carefully replace the old rubber with the new one, being mindful to line the cover up correctly with the outside edge of the device as well as the inner cover.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
3 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Blake Rounds
メンバー登録日: 02/17/15
363 ポイント
1ガイドが承認済み
チーム
USF Tampa, Team 1-1, Blackwell Winter 2015 USF Tampa, Team 1-1, Blackwell Winter 2015人のメンバー
USFT-BLACKWELL-W15S1G1
4 メンバー
2のガイドは作成済み
1件のガイドコメント
Thanks a ton for taking the time to consider this obvious, likely possibility, and actually documenting and sharing your work-around solution. It is also is handy because it reminds potential buyers that this cute and otherwise cool and super affordable speaker, while a real natural stocking stuffer, might be one of those cheapo gifts that I think a lot of us are getting sick of: fun to get, fun to use, and a downer when you throw away three weeks later. So maybe they made a bad decision on just one part, the sticky part. Customers are pretty cool about understanding that things happen when you try something new. But The fact that this article exists suggests they made a choice not to offer reasonable after purchase support, like I don’t know 10 bucks for a set of Sticky backs? Sure they’re cheap, so don’t hold it a ripoff, and theres probably a market for people who have a need for a short term hrowaway. Anyway you get the gist, and I should pay more attention to the fricking website name.
Legal Labs - 返信 共有
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 17
今までの合計 6,826
