メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Google Pixel C Speaker Replacement
必要な工具と部品
  1. Google Pixel C Speaker Replacement, Screen: 手順 1、 1の画像 1
    • Ensure that the device is completely powered down before beginning to take it apart
    • Use a heat gun to melt the adhesive that holds the screen to the device
    • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
    • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
    FixBotに聞いてみる
    コメントを追加
  2. Google Pixel C Speaker Replacement: 手順 2、 2の画像 1 Google Pixel C Speaker Replacement: 手順 2、 2の画像 2
    • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
    • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
    • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
    • Reattaching the screen will require adhesive to ensure that it stays in place.
    FixBotに聞いてみる
    コメントを追加
  3. Google Pixel C Speaker Replacement: 手順 3、 2の画像 1 Google Pixel C Speaker Replacement: 手順 3、 2の画像 2
    • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
    FixBotに聞いてみる
    コメントを追加
  4. Google Pixel C Speaker Replacement: 手順 4、 2の画像 1 Google Pixel C Speaker Replacement: 手順 4、 2の画像 2
    この手順で使用する道具:
    • Follow the same removal procedure to detach the wide gold cable.
    • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
    • This device is missing a battery, so the device that you are working on may appear slightly different inside.
    FixBotに聞いてみる
    コメントを追加
  5. Google Pixel C Speaker Replacement, Speaker: 手順 5、 1の画像 1
    • Locate the thin black speakers along the right and left sides of the tablet.
    • The longer speaker is secured by two different types of screws, while the shorter one is secured by two of the same type of screw.
    FixBotに聞いてみる
    コメントを追加
  6. Google Pixel C Speaker Replacement: 手順 6、 1の画像 1
    • Use the Phillips #000 screwdriver to remove the three 4.2mm screws
    • Use the same screwdriver to remove the 2.5mm screw as well.
    FixBotに聞いてみる
    コメントを追加
  7. Google Pixel C Speaker Replacement: 手順 7、 3の画像 1 Google Pixel C Speaker Replacement: 手順 7、 3の画像 2 Google Pixel C Speaker Replacement: 手順 7、 3の画像 3
    • Locate the two circular metal caps that are attached to the short speaker via a small cable and gently pull them out of the device
    • Locate and detach the third cable cap that is attached to the longer speaker.
    • The third cable runs along the upper edge of the device, and is secured down with adhesive.
    FixBotに聞いてみる
    コメントを追加
  8. Google Pixel C Speaker Replacement: 手順 8、 1の画像 1
    • Slide both speakers out from the edges of the device.
    FixBotに聞いてみる
    コメントを追加
  9. Google Pixel C Speaker Replacement: 手順 9、 3の画像 1 Google Pixel C Speaker Replacement: 手順 9、 3の画像 2 Google Pixel C Speaker Replacement: 手順 9、 3の画像 3
    • Locate the red and black twisted wires.
    • Use a spudger to pry under the cable and pop it free from the attachment, fully detaching the speaker from the device.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
4人の作成者と共同で作成されました。
Isabelle Tang
メンバー登録日: 04/26/17
225 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S21-G4, Livingston Spring 2017 Cal Poly, Team S21-G4, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S21G4
4 メンバー
11のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 38
今までの合計 1,253
