メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Google Pixel C Power Button Replacement
必要な工具と部品
    1. Google Pixel C Power Button Replacement, Screen: 手順 1、 1の画像 1
      • Ensure that the device is completely powered down before beginning to take it apart
      • Use a heat gun to melt the adhesive that holds the screen to the device
      • Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
      • Make sure not to heat the screen for too long because too much can damage other components inside the tablet.
      FixBotに聞いてみる
      コメントを追加
    2. Google Pixel C Power Button Replacement: 手順 2、 2の画像 1 Google Pixel C Power Button Replacement: 手順 2、 2の画像 2
      • Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
      • If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
      • Be careful not to pull the screen too far off. It will still be attached to the device by a cable for the front facing camera and the wide display data cable.
      • Reattaching the screen will require adhesive to ensure that it stays in place.
      FixBotに聞いてみる
      コメントを追加
    3. Google Pixel C Power Button Replacement: 手順 3、 2の画像 1 Google Pixel C Power Button Replacement: 手順 3、 2の画像 2
      • Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
      FixBotに聞いてみる
      コメントを追加
    4. Google Pixel C Power Button Replacement: 手順 4、 2の画像 1 Google Pixel C Power Button Replacement: 手順 4、 2の画像 2
      この手順で使用する道具:
      • Follow the same removal procedure to detach the wide gold cable.
      • When reattaching cables, it is helpful to use tweezers to slide the cable in before securing it down with the flap.
      • This device is missing a battery, so the device that you are working on may appear slightly different inside.
      FixBotに聞いてみる
      コメントを追加
    1. Google Pixel C Power Button Replacement, Power Button: 手順 5、 1の画像 1
      • Locate the power button along the edge of the tablet.
      • The actual power button technology is the black plastic piece located directly inside the device behind the silver button; this is what will be replaced.
      FixBotに聞いてみる
      コメントを追加
    2. Google Pixel C Power Button Replacement: 手順 6、 2の画像 1 Google Pixel C Power Button Replacement: 手順 6、 2の画像 2
      • Locate and remove the black 4.3mm Phillips #000 screw.
      • Remove the remaining two silver 4.2mm Phillips #000 screws.
      FixBotに聞いてみる
      コメントを追加
    3. Google Pixel C Power Button Replacement: 手順 7、 2の画像 1 Google Pixel C Power Button Replacement: 手順 7、 2の画像 2
      この手順で使用する道具:
      • Use tweezers to slowly pull up on the power button technology as far as possible without pulling out the two black wires attached.
      • Don't pull up too hard, as the wires could be ripped out and damaged.
      FixBotに聞いてみる
      コメントを追加
    4. Google Pixel C Power Button Replacement: 手順 8、 2の画像 1 Google Pixel C Power Button Replacement: 手順 8、 2の画像 2
      • Detach the larger connector wire by flipping the copper hinge located at the base of the connection with your fingernail.
      FixBotに聞いてみる
      コメントを追加
    5. Google Pixel C Power Button Replacement: 手順 9、 1の画像 1
      • Flip the hinge of the second, more narrow wire to release the connection.
      • Don't pull the power button technology out yet. This wire is attached at one more place in the device.
      FixBotに聞いてみる
      コメントを追加
    6. Google Pixel C Power Button Replacement: 手順 10、 2の画像 1 Google Pixel C Power Button Replacement: 手順 10、 2の画像 2
      • Locate and remove the three 4.2mm Phillips #000 screws at the base of where the second wire is still connected.
      FixBotに聞いてみる
      コメントを追加
    7. Google Pixel C Power Button Replacement: 手順 11、 2の画像 1 Google Pixel C Power Button Replacement: 手順 11、 2の画像 2
      • Once all the screws are removed, gently pull up on the entire power button technology piece, to remove it from the device.
      FixBotに聞いてみる
      コメントを追加
終わりに
To reassemble your device, follow these instructions in reverse order. New adhesive will be needed to re-apply the screen.
キャンセル: このガイドを終了できませんでした。
ある他の人がこのガイドを完成しました。
作成者
3人の作成者と共同で作成されました。
Isabelle Tang
メンバー登録日: 04/26/17
225 ポイント
2のガイドは作成済み
チーム
Cal Poly, Team S21-G4, Livingston Spring 2017 Cal Poly, Team S21-G4, Livingston Spring 2017人のメンバー
CPSU-LIVINGSTON-S17S21G4
4 メンバー
11のガイドは作成済み
1件のガイドコメント
I have replaced the power/volume button flex with these instructions with a reportably working item, but power button still doesn't work. The volume buttons work just fine. Any other ideas about what might be the problem?
Colleen Price - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 53
今までの合計 3,153
