メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GoPro Hero3+ Silver Edition Camera Lens Replacement
必要な工具と部品
  1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: 手順 1、 2の画像 1 GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: 手順 1、 2の画像 2
    • Push the tab on the back of the device left to remove the plate covering the battery.
    FixBotに聞いてみる
    コメントを追加
  2. GoPro Hero3+ Silver Edition Camera Lens Replacement: 手順 2、 1の画像 1
    • Use the strip of tape on the battery to remove the battery from the housing.
    FixBotに聞いてみる
    コメントを追加
  3. GoPro Hero3+ Silver Edition Camera Lens Replacement, Front Panel: 手順 3、 1の画像 1
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
    FixBotに聞いてみる
    コメントを追加
  4. GoPro Hero3+ Silver Edition Camera Lens Replacement: 手順 4、 1の画像 1
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
    FixBotに聞いてみる
    コメントを追加
  5. GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: 手順 5、 3の画像 1 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: 手順 5、 3の画像 2 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: 手順 5、 3の画像 3
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
    FixBotに聞いてみる
    コメントを追加
  6. GoPro Hero3+ Silver Edition Camera Lens Replacement: 手順 6、 2の画像 1 GoPro Hero3+ Silver Edition Camera Lens Replacement: 手順 6、 2の画像 2
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
    FixBotに聞いてみる
    コメントを追加
  7. GoPro Hero3+ Silver Edition Camera Lens Replacement: 手順 7、 1の画像 1
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
    FixBotに聞いてみる
    コメントを追加
  8. GoPro Hero3+ Silver Edition Camera Lens Replacement: 手順 8、 2の画像 1 GoPro Hero3+ Silver Edition Camera Lens Replacement: 手順 8、 2の画像 2
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
    FixBotに聞いてみる
    コメントを追加
  9. GoPro Hero3+ Silver Edition Camera Lens Replacement, microSD/Expansion Port Assembly: 手順 9、 1の画像 1
    • Using your screwdriver, unscrew three 4mm PH00 screws that will free the metal plate.
    • A small plate will become separated when the rightmost screw is removed. Just place it to the side.
    FixBotに聞いてみる
    コメントを追加
  10. GoPro Hero3+ Silver Edition Camera Lens Replacement: 手順 10、 2の画像 1 GoPro Hero3+ Silver Edition Camera Lens Replacement: 手順 10、 2の画像 2
    • Use the plastic opening tool to pry off the referenced ribbon cable from the motherboard.
    • The microSD and Accessory Board is now ready for removal.
    FixBotに聞いてみる
    コメントを追加
  11. GoPro Hero3+ Silver Edition Camera Lens Replacement, Motherboard: 手順 11、 1の画像 1
    • Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
    FixBotに聞いてみる
    コメントを追加
  12. GoPro Hero3+ Silver Edition Camera Lens Replacement: 手順 12、 3の画像 1 GoPro Hero3+ Silver Edition Camera Lens Replacement: 手順 12、 3の画像 2 GoPro Hero3+ Silver Edition Camera Lens Replacement: 手順 12、 3の画像 3
    この手順で使用する道具:
    • Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard.
    • Gently remove the motherboard from the midframe using tweezers.
    • Remove motherboard by lifting from the edges. This will reduce the chance of damaging components on the motherboard.
    FixBotに聞いてみる
    コメントを追加
  13. GoPro Hero3+ Silver Edition Camera Lens Replacement, Camera Lens: 手順 13、 1の画像 1
    • Use your PH00 screwdriver to remove the last three screws from the mid frame. This will release the lens housing from the mid frame.
    FixBotに聞いてみる
    コメントを追加
  14. GoPro Hero3+ Silver Edition Camera Lens Replacement: 手順 14、 1の画像 1
    • Carefully remove the lens from the font housing.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
9 の人々がこのガイドを完成させました。
作成者
5人の作成者と共同で作成されました。
Patrick Cook
メンバー登録日: 10/01/15
699 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 5-8, Maness Fall 2015 Cal Poly, Team 5-8, Maness Fall 2015人のメンバー
CPSU-MANESS-F15S5G8
4 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 9
過去 30 日: 34
今までの合計 2,565
