はじめに
If you memory card is corrupt or not working, this guide will demonstrate how to locate the memory card and replace it with a new one.
必要な工具と部品
Begin by removing the 5 screws (located: 2 screws on either side and 1 screw on the bottom) using the PH000 head in the Precision Phillips Screwdriver.
After the casing is removed, use your fingers to carefully lift up on the rubber pad, if it didn't already fall out during step 4.
After the pad is removed, the 2 Phillips head screws holding the control board will be exposed.
Locate the six 1.5mm Phillips screws that are holding on the interior camera frame.
Using the Phillips precision screwdriver and the PH000 Phillips bit, remove the 6 screws.
With the screws removed, the interior frame will no longer be fastened to the camera body and can be lifted up and away.
Locate the memory card slot in the bottom right corner of the camera.
Using a plastic opening tool, gently pry up on the edges of the bottom right corner of the control board.
Gently raise the lower right corner of the circuit board by prying upwards with an opening tool.
