メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Gateway Solo 1450 Screen Replacement
必要な工具と部品
  1. Gateway Solo 1450 Screen Replacement, Battery: 手順 1、 1の画像 1
    • Make sure the device is powered down and disconnected from any power sources. Doing this will eliminate any electrical hazards while working on the device.
    • First it is necessary to locate the battery release button. With the laptop orientated so that the screen hinges are facing up the button is located about halfway up the laptop and slightly to the left.
    FixBotに聞いてみる
    コメントを追加
  2. Gateway Solo 1450 Screen Replacement: 手順 2、 2の画像 1 Gateway Solo 1450 Screen Replacement: 手順 2、 2の画像 2
    • The next step is to simultaneously push up on the battery release button and to pull out on the battery itself. If this is not done simultaneously then the battery will not budge.
    FixBotに聞いてみる
    コメントを追加
  3. Gateway Solo 1450 Screen Replacement: 手順 3、 1の画像 1
    • To fully free the battery it is necessary to firmly grasp the battery and give it a firm tug.
    FixBotに聞いてみる
    コメントを追加
  4. Gateway Solo 1450 Screen Replacement, Keyboard: 手順 4、 2の画像 1 Gateway Solo 1450 Screen Replacement, Keyboard: 手順 4、 2の画像 2
    • Orient the laptop open to see the keyboard. Have the screen tilted all of the way back for easier access as shown.
    FixBotに聞いてみる
    コメントを追加
  5. Gateway Solo 1450 Screen Replacement: 手順 5、 1の画像 1
    • Above the keyboard, locate the plastic part containing the power button along with various other command buttons. This needs to come off before you can access the keyboard.
    • Use the spudger to assist in this step. Using the spudger, wedge it underneath the component.
    • Once spudger is inserted and pulled far enough, grasp it and firmly, but carefully, pull it out from the left side first
    FixBotに聞いてみる
    コメントを追加
  6. Gateway Solo 1450 Screen Replacement: 手順 6、 3の画像 1 Gateway Solo 1450 Screen Replacement: 手順 6、 3の画像 2 Gateway Solo 1450 Screen Replacement: 手順 6、 3の画像 3
    • Once unattached from left side, proceed to right side of component and remove it from clips it is attached to.
    • Once removed from clamps, the part is now removed to provide access to the keyboard.
    FixBotに聞いてみる
    コメントを追加
  7. Gateway Solo 1450 Screen Replacement: 手順 7、 2の画像 1 Gateway Solo 1450 Screen Replacement: 手順 7、 2の画像 2
    • The two J0 screws have now become visible. Using the Phillips J0 screwdriver, remove screws. The screws are 5mm long J0 Philips screws.
    FixBotに聞いてみる
    コメントを追加
  8. Gateway Solo 1450 Screen Replacement: 手順 8、 3の画像 1 Gateway Solo 1450 Screen Replacement: 手順 8、 3の画像 2 Gateway Solo 1450 Screen Replacement: 手順 8、 3の画像 3
    • Once screws are removed, firmly grasp the top edge of the keyboard and wiggle it slightly while firmly tugging on it. This will release the clips holding it.
    • Once clips become unattached, the keyboard is now out.
    FixBotに聞いてみる
    コメントを追加
  9. Gateway Solo 1450 Screen Replacement, Screen: 手順 9、 1の画像 1
    • Locate the 2 hinge protectors covering the laptop's hinges.
    • If not already done while you removed the keyboard, unscrew the screws holding the hinge protectors in place.
    FixBotに聞いてみる
    コメントを追加
  10. Gateway Solo 1450 Screen Replacement: 手順 10、 3の画像 1 Gateway Solo 1450 Screen Replacement: 手順 10、 3の画像 2 Gateway Solo 1450 Screen Replacement: 手順 10、 3の画像 3
    • Spudger the hinge protectors from the hinges.
    • Remove the hinge protectors from the hinges.
    FixBotに聞いてみる
    コメントを追加
  11. Gateway Solo 1450 Screen Replacement: 手順 11、 2の画像 1 Gateway Solo 1450 Screen Replacement: 手順 11、 2の画像 2
    • Locate the 2 pairs of screws that are on each hinge.
    • Unscrew the screws connecting the screen with the hinges.
    FixBotに聞いてみる
    コメントを追加
  12. Gateway Solo 1450 Screen Replacement: 手順 12、 2の画像 1 Gateway Solo 1450 Screen Replacement: 手順 12、 2の画像 2
    • Locate where the screen is connected to the laptop's interior.
    • Locate the 2 screws fixing this connection into place.
    • Unscrew the screws holding the connection between the screen and the laptop's interior in place.
    FixBotに聞いてみる
    コメントを追加
  13. Gateway Solo 1450 Screen Replacement: 手順 13、 3の画像 1 Gateway Solo 1450 Screen Replacement: 手順 13、 3の画像 2 Gateway Solo 1450 Screen Replacement: 手順 13、 3の画像 3
    • Locate the small piece of plastic above the connection between the screen and the laptop's interior.
    • Carefully insert a spudger into this piece of plastic and separate the connection from the laptop's interior.
    • Remove the connection from the laptop's interior.
    FixBotに聞いてみる
    コメントを追加
  14. Gateway Solo 1450 Screen Replacement: 手順 14、 1の画像 1
    • Separate the laptop's screen from the rest of the laptop.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
1人の作成者と共同作成されました。
Zachary Perry
メンバー登録日: 03/20/18
484 ポイント
4のガイドは作成済み
チーム
UMass Dartmouth, Team S5-G4, Peak Spring 2018 UMass Dartmouth, Team S5-G4, Peak Spring 2018人のメンバー
UMASSD-PEAK-S18S5G4
3 メンバー
12のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 28
今までの合計 532
