メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Gateway NV52 Keyboard Replacement
必要な工具と部品
  1. Gateway NV52 Keyboard Replacement, Battery: 手順 1、 1の画像 1
    • Turn the laptop on its backside with the stickers and barcode facing you.
    • Locate the latches on the top left corner.
    FixBotに聞いてみる
    コメントを追加
  2. Gateway NV52 Keyboard Replacement: 手順 2、 1の画像 1
    • In order to unlock the battery, slide the vertical latch downward where it indicates the unlocking icon.
    FixBotに聞いてみる
    コメントを追加
  3. Gateway NV52 Keyboard Replacement: 手順 3、 1の画像 1
    • Slide the horizontal latch to the right to pop open the battery pack.
    FixBotに聞いてみる
    コメントを追加
  4. Gateway NV52 Keyboard Replacement, Keyboard: 手順 4、 1の画像 1
    • Remove the five identical 9/32" Phillips Screws located under the battery and both upper corners using the Phillips #0 Screwdriver.
    FixBotに聞いてみる
    コメントを追加
  5. Gateway NV52 Keyboard Replacement: 手順 5、 1の画像 1
    この手順で使用する道具:
    Heavy-Duty Spudger
    • Flip the Device so the keyboard and display screen are faced upright.
    • Lift up the media button board cover using the Heavy Duty Spudger. Apply a minimum amount of upward force to the media button board cover at the right bottom corner. Starting from the right, continuously lift the cover to the left edge until completely separated.
    • Do not lift up the media button board cover too much, it’s still connected to the motherboard. Set the media button board cover upside down on the keyboard.
    FixBotに聞いてみる
    コメントを追加
  6. Gateway NV52 Keyboard Replacement: 手順 6、 1の画像 1
    • Disconnect the dark colored locking tab by pulling at a 90 degree angle, and then slightly pull away the ribbon from the locking tab.
    FixBotに聞いてみる
    コメントを追加
  7. Gateway NV52 Keyboard Replacement: 手順 7、 1の画像 1
    • Lift up the keyboard with the Spudger. Rotate the keyboard until its faced down on top of its base.
    • The keyboard is still connected to the access keyboard connector, so do not attempt to detach the keyboard from the laptop, yet.
    FixBotに聞いてみる
    コメントを追加
  8. Gateway NV52 Keyboard Replacement: 手順 8、 1の画像 1
    • Disconnect the brown-colored locking tab by pulling at a 90 degree angle and slightly pulling away from the locking tab.
    • Do not apply too much force to the locking tab, because a damaged connector will disable the keyboard.
    • Remove the keyboard, and placed it in a safe and dry place.
    FixBotに聞いてみる
    コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
4人の作成者と共同で作成されました。
Tim En
メンバー登録日: 01/26/13
557 ポイント
4のガイドは作成済み
チーム
Cal Poly, Team 7-24, Regan Spring 2014 Cal Poly, Team 7-24, Regan Spring 2014人のメンバー
CPSU-REGAN-S14S7G24
4 メンバー
18のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 41
今までの合計 2,691
