メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Garmin StreetPilot c320 LCD Screen Replacement
必要な工具と部品
    1. Garmin StreetPilot c320 LCD Screen Replacement, Rear Case Assembly: 手順 1、 2の画像 1 Garmin StreetPilot c320 LCD Screen Replacement, Rear Case Assembly: 手順 1、 2の画像 2
      • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
      • Pry the outer frame off the perimeter of the rear panel assembly.
      • The cover will easily pop off.
      FixBotに聞いてみる
      コメントを追加
    2. Garmin StreetPilot c320 LCD Screen Replacement: 手順 2、 2の画像 1 Garmin StreetPilot c320 LCD Screen Replacement: 手順 2、 2の画像 2
      • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
      • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
      • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
      FixBotに聞いてみる
      コメントを追加
    3. Garmin StreetPilot c320 LCD Screen Replacement: 手順 3、 1の画像 1
      • Gently pull the battery cable connector from its socket on the motherboard.
      • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
      FixBotに聞いてみる
      コメントを追加
    1. Garmin StreetPilot c320 LCD Screen Replacement, LCD Screen: 手順 4、 1の画像 1
      • Remove the two Phillips #00 screws securing the motherboard to the front case assembly.
      FixBotに聞いてみる
      コメントを追加
    2. Garmin StreetPilot c320 LCD Screen Replacement: 手順 5、 1の画像 1
      • Slightly lift the motherboard upwards to reveal the LCD assembly.
      • Do not remove the motherboard yet, as it is stil attached to the LCD.
      FixBotに聞いてみる
      コメントを追加
    3. Garmin StreetPilot c320 LCD Screen Replacement: 手順 6、 1の画像 1
      • Use the edge of a plastic opening tool to flip up the retaining flap on the LCD ribbon cable ZIF socket.
      • Be sure you are prying up on the hinged retaining flap, not the socket itself.
      • Use the plastic opening tool to pull the LCD ribbon cable out of its socket.
      • Disconnect the right connector using the edge of a plastic opening tool.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
作成者
7人の作成者と共同で作成されました。
Arturo Barajas
メンバー登録日: 01/18/12
11 ポイント
3のガイドは作成済み
チーム
Cal Poly, Team 11-19, Maness Winter 2012 Cal Poly, Team 11-19, Maness Winter 2012人のメンバー
CPSU-MANESS-W12S11G19
4 メンバー
12のガイドは作成済み
1件のガイドコメント
Geometry Dash World delivers short levels that are full of speed and excitement. Every jump must be timed carefully to avoid failure. The vibrant graphics and electronic music make the gameplay feel alive. It’s addictive from the very first level.
Ricky Graham - 返信 共有
コメントを追加
統計データ:
過去 24時間: 2
過去 7 日: 8
過去 30 日: 24
今までの合計 1,845
