はじめに
A step-by-step guide to replacing the screen of the Garmin Nuvi 680.
必要な工具と部品
Locate the antenna on the back of the device and gently flip it open to reveal the screws underneath.
Remove the two 4.42 mm screws in the top-left and top-right corners of the antenna cover using a T5 Torx screwdriver
Insert the pointed end of a spudger into the leftmost slit at the top of the antenna case, where you previously removed the circuit board
Once the spudger is inserted into the leftmost end of the slit at the top of the antenna case, slide it to the rightmost side of the slit.
Slide the antenna case out of the device.
Identify the antenna assembly, which is now exposed after removing the antenna cover.
The two screws are positioned at the top-left and top-right corners of the antenna assembly
Use a T5 Torx screwdriver to remove the 10.82 mm screws from the top-left and top-right corners of the antenna assembly.
Using your iFixit Opening Tool, gently insert a flat end of the tool into the slit of the top cover.
Use the Opening Tool and your hands to pull apart the front and back of the device. Grip the top and bottom sides with your hand while inserting the tool into the slit to gently separate the two halves
Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
Remove the antenna.
Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
Gently pull the ribbon cables out of their connectors. They should slide out easily.
Push the tabs towards the outside of the case, the tabs are located as shown.
Push the screen out of the case after the tabs are loosened.
Slide the screen out of the cover.
4 の人々がこのガイドを完成させました。
