メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Garmin Nuvi 680 Battery Replacement
必要な工具と部品
    1. Garmin Nuvi 680 Battery Replacement, Outer Case: 手順 1、 1の画像 1
      • Locate the antenna on the back of the device and gently flip it open to reveal the screws underneath.
      • Remove the two 4.42 mm screws in the top-left and top-right corners of the antenna cover using a T5 Torx screwdriver
      FixBotに聞いてみる
      コメントを追加
    2. Garmin Nuvi 680 Battery Replacement: 手順 2、 1の画像 1
      • Remove the antenna cover.
      • Set the removed cover aside carefully.
      FixBotに聞いてみる
      コメントを追加
    3. Garmin Nuvi 680 Battery Replacement: 手順 3、 1の画像 1
      • The yellow wire is connected to the motherboard. Do not disconnect it until you finish opening the device.
      • Locate the green antenna circuit board in the middle of the case.
      • Gently use 1 or 2 fingers to grab and pull the antenna circuit board out of the middle of the case.
      FixBotに聞いてみる
      コメントを追加
    4. Garmin Nuvi 680 Battery Replacement: 手順 4、 2の画像 1 Garmin Nuvi 680 Battery Replacement: 手順 4、 2の画像 2
      • Insert the pointed end of a spudger into the leftmost slit at the top of the antenna case, where you previously removed the circuit board
      • Once the spudger is inserted into the leftmost end of the slit at the top of the antenna case, slide it to the rightmost side of the slit.
      • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
      • Slide the antenna case out of the device.
      • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
      FixBotに聞いてみる
      コメントを追加
    5. Garmin Nuvi 680 Battery Replacement: 手順 5、 1の画像 1
      • Identify the antenna assembly, which is now exposed after removing the antenna cover.
      • The two screws are positioned at the top-left and top-right corners of the antenna assembly
      • Use a T5 Torx screwdriver to remove the 10.82 mm screws from the top-left and top-right corners of the antenna assembly.
      FixBotに聞いてみる
      コメントを追加
    6. Garmin Nuvi 680 Battery Replacement: 手順 6、 2の画像 1 Garmin Nuvi 680 Battery Replacement: 手順 6、 2の画像 2
      • Locate the top side of the outer case.
      • Using your iFixit Opening Tool, gently insert a flat end of the tool into the slit of the top cover.
      • Use the Opening Tool and your hands to pull apart the front and back of the device. Grip the top and bottom sides with your hand while inserting the tool into the slit to gently separate the two halves
      • One end of the front and back of the outer case are still connected by ribbon cables.
      FixBotに聞いてみる
      コメントを追加
    1. Garmin Nuvi 680 Battery Replacement, Antenna: 手順 7、 2の画像 1 Garmin Nuvi 680 Battery Replacement, Antenna: 手順 7、 2の画像 2
      • Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
      • Remove the antenna.
      FixBotに聞いてみる
      コメントを追加
    1. Garmin Nuvi 680 Battery Replacement, Screen Wiring: 手順 8、 1の画像 1
      • Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
      • Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
      • Gently pull the ribbon cables out of their connectors. They should slide out easily.
      • Do not separate the two halves of the device yet or the on/off cable may be severed.
      FixBotに聞いてみる
      コメントを追加
    2. Garmin Nuvi 680 Battery Replacement: 手順 9、 2の画像 1 Garmin Nuvi 680 Battery Replacement: 手順 9、 2の画像 2
      • Gently pull the cable for the on/off button straight up to remove it.
      • The two halves of the device may now be separated.
      FixBotに聞いてみる
      コメントを追加
    1. Garmin Nuvi 680 Battery Replacement, Motherboard: 手順 10、 1の画像 1
      • Use a Phillips #1 screwdriver to remove the two 6.88 mm screws located towards the center of the motherboard.
      FixBotに聞いてみる
      コメントを追加
    2. Garmin Nuvi 680 Battery Replacement: 手順 11、 2の画像 1 Garmin Nuvi 680 Battery Replacement: 手順 11、 2の画像 2
      • Carefully separate the motherboard from the outer case or the speaker and battery cables may be damaged.
      • Use a spudger to lift the edge of the motherboard.
      • Insert it at the bottom and use it as leverage to slowly release the motherboard from the case.
      FixBotに聞いてみる
      コメントを追加
    3. Garmin Nuvi 680 Battery Replacement: 手順 12、 1の画像 1
      • Gently unplug the cable for the battery. It has a red and black cable.
      • Pull it straight up and away from the motherboard.
      • Gently unplug the cable for the speaker. It has a blue and black cable.
      FixBotに聞いてみる
      コメントを追加
    4. Garmin Nuvi 680 Battery Replacement: 手順 13、 1の画像 1
      • Gently lift the motherboard straight up and out of the outer case.
      • There should be no wires attached to it.
      FixBotに聞いてみる
      コメントを追加
    1. Garmin Nuvi 680 Battery Replacement, Battery: 手順 14、 2の画像 1 Garmin Nuvi 680 Battery Replacement, Battery: 手順 14、 2の画像 2
      • The battery is difficult to remove because it's glued to the case.
      • Use a spudger to gently pry the battery out of its slot.
      • Remove the battery.
      FixBotに聞いてみる
      コメントを追加
終わりに
キャンセル: このガイドを終了できませんでした。
2 の人々がこのガイドを完成させました。
作成者
6人の作成者と共同で作成されました。
Chris Marzano
メンバー登録日: 01/20/11
968 ポイント
6のガイドは作成済み
チーム
Cal Poly, Team 5-22, Amido Winter 2011 Cal Poly, Team 5-22, Amido Winter 2011人のメンバー
CPSU-AMIDO-W11S5G22
5 メンバー
21のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 4
過去 7 日: 11
過去 30 日: 40
今までの合計 11,985
