はじめに
This guide will show how to safely replace the battery without damaging other parts of the board, or the battery itself.
必要な工具と部品
Remove the Phillips #00 screw on the side of the Game Boy closest to the directional pad.
Once the screw has been loosened, lift the cover off the back of the device.
Grip, and gently pull outwards on the cable as close to the battery connector as you can
ある他の人がこのガイドを完成しました。
