はじめに
初代Game Boyの白黒液晶画面へのアクセス方法と交換方法。これは上級者向けの修理です。この修理を完了するには、はんだ付けの方法を知っている必要がありますので、iFixitの 半田付けガイドを必ず参照してください。
注意:Game Boyのディスプレイによく起こる「縦線」の問題がある場合、新しいものに交換するよりも古いスクリーンを修理する方が簡単です。古いスクリーンの修理については、このガイドに従ってください。
必要な工具と部品
回路基板とスクリーンを固定している3つのプラスチック製クリップを外します。
I didn’t find this step necessary as the plastic screen holding unit is separate from the screen.
デバイスを再組み立てする際は、これらのインストラクションを逆の順番に従って作業を進めてください。
45 の人々がこのガイドを完成させました。
以下の翻訳者の皆さんにお礼を申し上げます:
100%
翻訳を始める ›
11 件のコメント
What kind of lcd screen or where can I find one that isn't off of another dmg-01 gameboy?
Floyd Odom - 返信
I was wondering the same. Maybe ebay or Amazon.
What about the new display? Where to get it?
No spare part necessary should be replaced with a link where to buy a new one.
You can’t buy a new replacement screen unfortunately. Not only is it very difficult to remove the screen, it’s impossible to buy a replacement. They’d be better showing us how to fix a screen. There’s plenty of videos on YT showing how to fix blank vertical line but hardly any on how to fix horizontal lines, and the ones that do don’t work very well.
Where do I buy a replacement screen for a 1989 game boy?
i suggest maybe going on ebay and finding a gameboy thats either just for parts or has a working screen and desoldering it
I tried following the video and ended up with burned tabs and melted plastic. Basically it’s all ruined. OP does a terrible job.
will this guide work to install a backlit LCD for the Game Boy? I have this Rips v4 backlit IPS LCD, and I figured I might as well install it.
if not, that's alright. I'll just find another guide.
AFAIK you can follow through the disassembly guide up to step 10 no problem, then it depends if you bought the full kit you simply swap the old screen and big PCB with the new ones; if you're planning to use the original GB case, notice you'll have to do some mods in order to fit in the new screen. Also, you might have to solder the speaker on the PCB. Here's a video you may want to check out when you're done disassembling the GB and will be ready to start installing the screen upgrade: https://www.youtube.com/watch?v=FMIJTbPe...
Simone -
bonjour ou puis je trouver l'ecran LCD ?
merci
