メインコンテンツにスキップ
Galaxy Book3 360 13" SSD Replacement
必要な工具と部品
  1. Galaxy Book3 360 13" SSD Replacement, Remove the Screws: 手順 1、 1の画像 1
    • Flip the laptop over and remove each rubber shoe
    • Use a Philips screwdriver to care fully remove each screw
  2. Galaxy Book3 360 13" SSD Replacement, Remove the Case: 手順 2、 2の画像 1 Galaxy Book3 360 13" SSD Replacement, Remove the Case: 手順 2、 2の画像 2
    • After removing the screws carefully pry open the case starting on the top right hinge.
    • There is a clip in the center of the laptop , when the edges are completely removed lift carefully to unclip the center.
  3. Galaxy Book3 360 13" SSD Replacement, Replace the SSD: 手順 3、 1の画像 1
    • Carefully remove the screw holding down the SSD.
    • Lift the SSD until it is at about a 10-degree angle and then slide it out of the socket.
    • Slide in your new SSD, and follow the previous steps in reverse.
終わりに
5 の人々がこのガイドを完成させました。
作成者
2人の作成者と共同で作成されました。
Dan
メンバー登録日: 02/18/19
4,433 ポイント
9のガイドは作成済み
5 件のコメント
Are you sure for the second slot it is 2280 and not 2230?
Jeremy Asher - 返信
How can I be sure for my NP750QFG that it's 2280 and not 2230?
Any advice?
Jeremy Asher - 返信
Galaxy book 3 360 15.6" inch variant support Gen 3 NVMe 2280 type ssd like WD Black SN770
Biswajit Shial -
Mine is 15.6 size and it's for the second slot, the 13" I think didn't have a second slot.
How do I know i it's for 2230 or 2280?
Jeremy Asher - 返信
I opened my Book3 Pro 360 5G and the SSD is covered by a metal shield. How do I remove this shield to gain access to the SSD and slot?
Lloyd Franklin - 返信
コメントを追加
統計データ:
過去 24時間: 13
過去 7 日: 109
過去 30 日: 400
今までの合計 12,566
