メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
GE Front-Load Washing Machine Damper Replacement
ビデオガイド
この修理ガイドはYouTubeビデオを書き起こしました。
必要な工具と部品
    • Press and hold the Start ⁄ Pause button for eight seconds to enter service mode.
    • Tap the same button once to display stored error numbers.
    • Scroll through the stored codes and look for any damper-related faults.
    • If a damper code appears, continue with electrical testing before parts replacement.
    FixBotに聞いてみる
    コメントを追加
    • Unplug the washer and close the water supply valves before opening the cabinet.
    • Have a Phillips screwdriver and a multimeter equipped with thin probe tips on hand.
    • Put on cut-resistant gloves to protect hands while handling sharp metal and the door gasket.
    FixBotに聞いてみる
    コメントを追加
    • Pull the detergent drawer out, press the rear release tab, and fully remove the drawer.
    • Take out five Phillips screws inside the dispenser recess, noting that the two center screws have a different thread than the outer three.
    • Lift the left side of the control interface about 20 degrees, slide it right, and pull it forward while supporting the attached wiring.
    FixBotに聞いてみる
    コメントを追加
    • Undo the three Phillips screws securing the rear edge of the top panel.
    • Slide the panel toward you and lift it off to expose the main control area.
    FixBotに聞いてみる
    コメントを追加
    • Remove one screw from the plastic shield and two screws from the metal cover.
    • Slide the metal cover forward to release it, then take out the final screw hidden underneath.
    FixBotに聞いてみる
    コメントを追加
    • Press the locking tabs and move the wire trunks away from the board for better probe access.
    FixBotに聞いてみる
    コメントを追加
    • Locate the blue three-wire harness in the center of the board and disconnect it by squeezing its latch.
    • Set the multimeter to 2 kΩ–20 kΩ or auto-range resistance mode.
    • Probe middle-to-left and middle-to-right pins; a healthy damper measures about 4.2 kΩ on each reading.
    • An open circuit or a value far from 4.2 kΩ indicates a failed damper or damaged wiring.
    • If readings are correct yet the fault persists, the control board may not be sending voltage to the damper.
    FixBotに聞いてみる
    コメントを追加
    • Insert a pick or small screwdriver at the 6 o’clock position, pry the spring clamp out of the groove, and peel the outer lip of the gasket off the front panel.
    FixBotに聞いてみる
    コメントを追加
    • Remove the three Phillips screws securing the damper assembly to the bulkhead.
    • Push the assembly rearward and then downward to disengage it from the front panel opening.
    FixBotに聞いてみる
    コメントを追加
    • Take out three screws from the washer bottom; tilting the unit backward may improve access.
    • Remove two screws from the door-lock facade and lift the facade away.
    • Undo the single screw holding the door lock, lift the lock up, and push it rearward inside the cabinet.
    • Extract seven screws along the top edge of the bulkhead; corrosion may require alternate bits.
    • Open the door, lift it slightly, pivot the front panel forward, and disconnect the left-side harness before removing the panel completely.
    FixBotに聞いてみる
    コメントを追加
    • Unscrew the metal retainer from the damper and separate the two halves with a hook tool.
    • Remove the screw beside the wire-tie anchor that holds the damper harness clip to the bulkhead.
    • Cut the existing cable tie and press the two small wings to release the harness block from its holder.
    • Disconnect the blue damper plug; the adjacent white plug powers the drum light.
    • Pull the damper body straight out of the gasket to remove it.
    FixBotに聞いてみる
    コメントを追加
    • Place the replacement damper between the gasket lips so it rests on the three molded ledges; a small gap above the plastic is normal.
    • Fit the metal retainer around the damper halves, press until it snaps, and reinstall its screw.
    • Reconnect the blue harness plug and lock the harness block back into its holder.
    • Secure the wiring with a fresh cable tie routed through the original anchor.
    FixBotに聞いてみる
    コメントを追加
    • Lift the damper assembly into its opening and reinstall the three Phillips screws.
    • Pull gently on the assembly to confirm it is firmly locked in place.
    FixBotに聞いてみる
    コメントを追加
    • Roll the gasket lip over the front panel rim while wearing gloves to avoid cuts.
    • Use a spring-expander tool, or a cable-tie and wrench method, to stretch the spring clamp and guide the wire around the gasket groove.
    • Release the tool slowly and press the clamp fully into the groove with a hook or screwdriver.
    FixBotに聞いてみる
    コメントを追加
    • Align the front panel on its locating pegs, reconnect the left-side harness, and pivot the panel into place.
    • Reinstall the door-lock screw and refit the facade with its two screws.
    • Replace the seven upper bulkhead screws followed by the three bottom screws.
    FixBotに聞いてみる
    コメントを追加
    • Set the top panel on the cabinet, slide it back, and secure it with three screws.
    • Hook the right side of the interface onto its stud, pivot the left side down, and press until it locks.
    • Install the five dispenser-area screws, matching the coarse-thread pair to the center holes.
    • Slide the detergent drawer back into the housing until it clicks.
    FixBotに聞いてみる
    コメントを追加
終わりに
Repair didn't go as planned? Ask our Answers community for help.
キャンセル: このガイドを終了できませんでした。
作成者
2人の作成者と共同で作成されました。
Ben Schlichter
メンバー登録日: 01/21/25
7,100 ポイント
224のガイドは作成済み
0件のガイドコメント
コメントを追加
統計データ:
過去 24時間: 8
過去 7 日: 33
過去 30 日: 96
今までの合計 428
